C63 Wrong oil problem?
Yesterday My 2008 C63 got an oil and filter change and now i have found out that the oil we filled on (mobil 3000 5w40 full synthetic ) was only 229.3 MB certified not 229.5 as M156 engines claims. Would this be any problem and could any damage happen with This oil in engine ? I am only drivning around 4500 miles before changing oil and filter normally. Hope for a good answer thanks
229.5 engine oils must be used with fleece oil filter designed for use with 229.5 engine oils.
That would indicate that 229.3 may cause an issue with the fleece oil filters - I don't think the fleece filter was ever available for the c63 - usually they only use paper type, I know mine is not a fleece type.
If it was my car, I would change it asap just for piece of mind though.
MB sheet 229.5 approved oils; "MB Longlife Service Oils"
for passenger cars with gas and diesel engines with extended drain intervals beyond 229.3 oils, to 30,000 km, min 1.8% fuel saving, first oils introduced summer 2002. For gas engines of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters).
