C63 AMG (W204) 2008 - 2015
Aftermarket Control Arms for Front Suspension
Old Dec 8, 2018 | 12:12 AM
Master Mustafa's Avatar
W205 c63 amg
Hi I've recently bought a 2010 c63amg that has moderate to bad suspension damage. ...i got around the coilovers by substituting with variant 3 KW coilovers. ....the rear control arms needed on-the-go left rear I obtained. The front however I can only get at excessive prices for original amg parts. Does anyone know if any particular aftermarket control arms are better/stronger than originals.
any advice would be welcomed. I've looked at Mevotech, URO, Beck Arnley, Delphi, Dorman, Febi, Lemfoerder, Moog, Rein, Centric and AC Delco.
Old Dec 8, 2018 | 02:02 AM
Catchyname's Avatar
2012 C63 w204 sedan
Lower control arms are AMG only, everything else is i believe is mercedes branded lemfoerder or delphi.
Ive always bought lemfoerder as I have owned bmw's previously and never had an issue, its OEM for BMW too.
Old Dec 8, 2018 | 01:47 PM
deadlyvt's Avatar
2010 C63 AMG
There are some thrust arms with beefier bushings installed
https://www.fcpeuro.com/products/mer...-works-mbcakit
Old Dec 8, 2018 | 11:05 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Those are not AMG cross struts (front LCA).
Old Dec 9, 2018 | 05:41 AM
deadlyvt's Avatar
2010 C63 AMG
Hence the thrust arm reference ?
Old Dec 9, 2018 | 11:42 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Yup. If the OP needs front thrust arms, those will work. They're not AMG specific and shared across the C platform. That's exactly what I had SDW do for me in the spring.
