C63 AMG (W204) 2008 - 2015
Seat Bolster Fix Ideas
Old Dec 11, 2018 | 08:36 PM
Sanders27's Avatar
C63 AMG
After driving a local FL and PFL I think I am going to stick with the PFL style. For whatever reason it just speaks to me in some way more than the FL models. However in looking at various ones online even lower mileage cars, the driver's bolster are pretty beat up. Are there any products out there that anyone has used to bring them back to life. I remember a couple years ago when looking for an older 911, there was something that I ran across but for the life of me I can't find it again or figure out what search term I used.
Thank you in advance for any help.
Old Dec 11, 2018 | 08:48 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
It isn't too hard but the only fix is to redye that section of the seat, there are a bunch of companies that will provide the product to do it for 50 bucks or so. Leatherique is one, but depending on your interior color, they may or may not have it - I used these guys, found they have porcelain and no one else did was a perfect match. https://leathermagic.com/mercedes-interior-colors/
It is pretty simple you cover what you don't want dye on, sand the worn bolster and clean with their cleaner, then wipe or spray on their dye a few coats, if it is really worn or cracked you can also fill it before coloring. Mine has held up like OEM, I found wiping it on matched the texture better than spraying.
These guys also have a lot of mercedes dye colors https://www.leatherworldtech.com/Mer...ors-s/1857.htm
Old Dec 11, 2018 | 08:50 PM
Sanders27's Avatar
C63 AMG
Awesome! That's exactly what I was thinking about.
Appreciate your time in responding and for including the links.
Old Dec 11, 2018 | 11:38 PM
skullbox15's Avatar
2014 C63
Does that work for the MB tex as well?
Old Dec 12, 2018 | 01:50 PM
Garret Ohm's Avatar
2016 VW Golf R
Not sure I'd try this for the first time on a Merc, but hard to argue with the before/after here:
Old Dec 12, 2018 | 03:45 PM
Drift1492's Avatar
Infiniti
Originally Posted by Garret Ohm
Not sure I'd try this for the first time on a Merc, but hard to argue with the before/after here: https://www.youtube.com/watch?v=gI04exWUkKI.
I thought about trying that but couldn't bring myself to do it. Instead I went with this:
autoleatherdye.com
The mercedes black kit matched my pfl black leather perfectly. I didn't fill the cracks though.
Old Dec 12, 2018 | 07:10 PM
Mort's Avatar
MB tex is a man made product of a type of vinyl/rubberized coating on a cloth fiber backing. Make sure whatever you try says it is compatible with it. If the solvents in the dye are too strong or the wrong type they may soften or dissolve the material coating or not absorb into it at all.
Old Dec 12, 2018 | 09:03 PM
Top Answer: 1
MB Tex is basically vinyl, the company I used also makes a vinyl re-coloring product that would work and they also have the factory vinyl colors in the color chart I linked in my first post. Here is the vinyl coloring product https://leathermagic.com/vinyl-plastic-recoloring-kit/
Old Dec 13, 2018 | 10:36 AM
sqitis's Avatar
C63 P31
Has anyone tried the product above with Porcelain Nappa leather?
Old Dec 13, 2018 | 02:56 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
Subbed for answer.
Old Dec 13, 2018 | 03:08 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Wouldn't you use their products for leather instead?
https://leathermagic.com/leather-car...tion-products/
Old Dec 13, 2018 | 03:10 PM
sqitis's Avatar
C63 P31
That's the same product as I meant. Or has anyone tried something else that also works well with the Porcelain?
Old Dec 13, 2018 | 05:07 PM
Top Answer: 1
i used it on my 507 with porcelain and the match is excellent I recommend not spraying as that gives more texture than OEM so called and they recommended wiping on to give oem smooth texture results.
rob
Old Dec 13, 2018 | 05:21 PM
sqitis's Avatar
C63 P31
rob
Awesome, thank you!
Old Dec 13, 2018 | 05:37 PM
Top Answer: 1
Awesome, thank you!
it is a bit scary the first time using sandpaper on your leather but it is top coated leather so it is basically like doing bodywork just with leather products, follow the instructions watch the video and it is not that hard maybe 1.5 hours to do my bolster and most of that is just drying between coats after you prep and do the first coat. If you can find some scrap leather I colored a piece first just to compare color or pick a piece in hidden area and do a little to check match before jumping into the deep end!
Old Dec 13, 2018 | 07:25 PM
EMTHED's Avatar
09 C63 AMG
Just ordered some as well, definitely curious how well it will turn out?? I'm also amazed theres no rub off into clothing??
Old Dec 13, 2018 | 08:08 PM
sqitis's Avatar
C63 P31
Got any before and after pictures so that we can see real results?
Old Dec 13, 2018 | 08:32 PM
Top Answer: 1
I don't didn't take any pics before, I can do an after, mine wasnt too bad at 30k miles, light cracking and medium wear I would say - will snap a pic of it currently when I have a minute.
Old Dec 13, 2018 | 08:41 PM
sqitis's Avatar
C63 P31
Ok cool, that works!
Old Dec 13, 2018 | 09:10 PM
Top Answer: 1
Ok, took a pic and attachment uploads are not working tonight, will try later and see if it has been resolved.
Old Dec 13, 2018 | 09:16 PM
Top Answer: 1
Ok JPG won't work, converted to PDF and attached for now.
Rob
File Type: pdf
Old Dec 14, 2018 | 06:44 AM
sqitis's Avatar
C63 P31
Rob
Oh wow, looks good! Did you use the crack filler on both the side bolster and hip bolster?
Old Dec 14, 2018 | 12:08 PM
2012 C63 AMG Sedan
roadkillrob,
would you think it could fix this?
Driver's side bolster
Driver's side bottom
Old Dec 14, 2018 | 01:30 PM
Top Answer: 1
I didn't have any real deep cracks, I just sanded and sprayed, did not need to fill.
Old Dec 14, 2018 | 01:32 PM
Top Answer: 1
Ya that would not be too tough to fix, a bit more worn than mine, but nothing too bad that will come out nice with some good cleaning and prepping and 3 or 4 coats of the dye - it dries pretty quick, I think I left it for 24 hours before using it and I put a soft sheet over it for another day when I drove it just ot give it more time and it has been almost a year now in the pic I posted since I did it (probably about 9 months to be exact). Thread is basically the same color so I just went over the thread also and it took the dye well and look like factory.
Originally Posted by SaphGreyC63
roadkillrob,
