C63 AMG (W204) 2008 - 2015
Steering wheel trim question?
Old Dec 16, 2018 | 01:31 PM
sqitis's Avatar
C63 P31
Quick question, is the chrome trim around the buttons on the FL steering wheel just clipped on or is there screws that hold it on? If there's screws, what's the best way to access them?
Any help would be great!
Old Dec 16, 2018 | 03:22 PM
myn8m3is8ndy's Avatar
2013 P31 C63 Coupe
there's two screws and to access them you need to remove the airbag.
Old Dec 16, 2018 | 04:04 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Yes, airbag has to be removed then 4 screws hold the trim, 2 behind airbag and 2 just in the backside of the bottom on the center lower spoke of the wheel.
Here is a DIY - from a CLA but same wheel . https://www.mercedescla.org/forum/62...r-install.html
Old Dec 16, 2018 | 08:15 PM
sqitis's Avatar
C63 P31
Awesome, thanks guys!!
Old Dec 17, 2018 | 11:23 AM
Mort's Avatar
Disconnect the battery and let the car sit for a while if you think you will need to unplug the airbag or it will set a code and you will need the dealer or Xentry to erase the code to reset SRS.
Old Dec 17, 2018 | 11:34 AM
sqitis's Avatar
C63 P31
I may try this with the batt hooked and hope for the best....LOL Really didn't look too tough in the write-up in the above post.
