Tire sizes
No. I run 265s with 12mm spacers and have no clearance. any wider would rub
1) 285s are too wide for stock 9 inch wide wheels. 2) I doubt 285s would fit with a 12 mm spacer. even with 265s I had a tiny spot near where the rear bumper attaches that rubbed (maybe 1-2 mm too much metal) that I had to shave with a dremel and touch up. I am also on H&R springs, but I still don't think 285s are a good idea or will fit.
yes, you can fit 285s with the correct wheel, but not a 285 on a stock wheel with a 12mm spacer. 285 is too wide for a 9 inch wheel and is also too wide for that low of an offset with our rear fenders.
