P30/P31 clarification
I'm looking at replacements and just had the VIN decoded. The vin decode shows the car is a P30 on a 2012 model car NOT P31
But
It DOES have 22P Track Package, red brakes, LSD, sport suspension, and most importantly TITANIUM colored intake manifold vs Silver
I honestly thought the P30 was for 2011 and DOWN, while P31 was 2012 +
And I also thought P31 was the only was to tell.
I am aware that the P31 engines had lighter and forged internals from the SLS.... Can anyone confirm or deny that the titanium intake tells you this?
Or just engine stamp.....
I'm buying the car out of state and hard to get info
I mean if this car has the forged and lightened internals....
What does a P31 do differently
But
Regards,
Joe
This is my question.
How can you know for sure - without seeing the engine stamp that it's a P31 ?
The P31 is simply an option package. It like others such as P01 don't show up on datacard. There is no identifier on the car that denotes the package.
ValveStud you were the one who decoded my vin originally, I didn't remember it correctly - its attached below
Thank you for correcting me
So that we are all clear 2012+ models with FL which have a P30 code will all have lighter weight and forged internals? Yes / No
Sorry, edit. He took apart a 507 engine which is the same as a P31, confirmed by Tasos. It had the SLS crankshaft and pistons. Regular rods, no different from any other C63. Videos below.
PRESS RELEASE
Performance Package Plus: enhanced performance for successful AMG model: C 63 AMG with a shot of SLS
Affalterbach – Enhanced driving dynamics ex factory for the Mercedes-Benz C 63 AMG: the new Performance Package Plus is an attractive optional extra that is designed to appeal to the power-hungry sports driver. The Performance Package Plus increases output by 22 kW/30 hp to 358 kW/487 hp. As a result, the C-Class approaches the level of performance offered by C-Class DTM vehicles, which deliver 377 kW/500 hp. The Performance Package Plus is available for the saloon and estate models and includes an AMG high-performance braking system featuring composite technology on the front axle, a carbon fibre spoiler lip (saloon) and an AMG performance steering wheel in nappa leather/Alcantara.
With the Performance Package Plus, the C 63 AMG accelerates from 0 to 100 km/h in 4.4 seconds and 0 to 200 km/h in 13.9 seconds. This beats the 336 kW/457 hp standard model by up to 1.2 seconds (0–100 km/h: 4.5 seconds; 0–200 km/h: 15.2 seconds). The top speed is 250 km/h (electronically limited).
The improvement in power output to 358 kW/487 hp is due to the AMG 6.3-litre V8 engine's modified engine compartment: the forged pistons adopted from the new SLS AMG super sports car together with new connecting rods and a lightweight crankshaft translate into a weight saving of three kilograms. Reduced inertia boosts the agility and responsiveness of the uprated V8 engine, which is recognisable from the variable intake manifold painted in titanium grey. New engine management completes the powertrain measures in the Performance Package Plus for the C 63 AMG.
Source:
https://www.autoblog.com/2009/10/21/...pired-c63-amg/
C63 Performance Package (2014 507 used as reference here, per Tasos' videos) has:
1. Upgraded Crankshaft from SLS (Non-Black Series), with weight savings of 4.96lb over the 2008 C63 (I assume Non-Performance Package)
2. Upraded Mahle brand Pistons from SLS (Non-Black Series), with different/lighter Wrist Pins, with total weight savings of 1.2lb (8 of them) over the 2008 C63
3. Same Connecting Rods as the 2008 C63. Tasos does not mention if these are the same Con Rods as in SLS or not. Perhaps AMG Marketing is still correct? :P
Maybe someone with Mercedes EPC access can check Con Rod part numbers for a PP C63 vs SLS (Non-BS)
They start with A1560300820, then they go through 5 generations..
This is weird, these engines must have a problem with con rods that these people were trying to solve.
The latest that I can see is 1560301220
Then there is (mind you for the 204 series) 1590300020
In the description for this part number, I see:
Output increase option 923
Special model AMG Black series P98
Option P61
I see that Output increase 923 is part of the P31 package. P61 is 507.
Now all these 3 have as a pre-requisite 204 model series, meaning, these con rods are not available in a M156 in a G series or S series, only in the W204.
Does it mention the Year this part went into production or was made available?
This same 1590300020 Con Rod - is it also in the SLS?
The 159* designation makes me think it may be
2013-2015 to compare the package of the p31, p61 and black series (i think its p90? )
just curious what the difference was beside aesthetics in the hood steering wheel, shift knob, and cluster
Thank you
Google search is your friend.
