Best tire for my W204 C63 in 2019
Nobody has mentioned RE-11's (or whatever the latest iteration is) which is an absolutely fantastic tire. My dad had them on his CaymanS and we loved them for track days so I picked up a set last year for my track wheels (19" Forgestars). They have huge tread blocks, sticky AF 180 tw rating (IIRC), and a couple deep/wide watershed channels so can handle some rain pretty well if needed (although it does do much better in the dry. It outperforms the 4S in the dry (not sure about the Cup2) if you're looking for another track tire option. For daily, I'm running Conti DW's on OEM 18's as wet performance is on par (if not a tad better) than the 4S, which is, of course, a little important when living in SoFla.
Trying my luck here in an old thread. I got a good deal on a used set of 19" OEM wheels (16 spoke). Wheels are fitted with pretty large tires:
Front 8"x J19H2 ET45: 245/40-R19
Rear: 9"x J19H2 ET54: 275/35-R19
Anyone know if I'll end up with rubbing issues? Car is stick on the p30 suspensions.
Car is currently in winter storage so have not been able to test the fitment, just curious if I need to fix this issue before spring or if I'm abel to run this set for a season?
