C63 AMG (W204) 2008 - 2015
M156 Tuning
Old May 28, 2019 | 05:30 PM
YYCStage3's Avatar
2012 C63 AMG P31, Stage 3 Weistec
M156 Tuning
Anyone out there have any good experiences with getting custom tuning done on their Supercharged M156's? I am currently running a Weistec Stage 3 on my p31 car. Also has Long tubes, Mid/hi-flow cats / Xpipe - it has plenty of power, but I'd like to squeeze as much out of it as I can when I do 1/4 and 1/2 mile events.
Also toying with the idea of a water/meth set up, ice tank, MS109 and the smaller 60mm pulley.
Anyone have luck with similar set ups?
Thanks!
Old May 28, 2019 | 06:55 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Thanks!
We tune them all the time
Old May 28, 2019 | 08:20 PM
PeterA90's Avatar
c63
I recommend leaving the Weistec tune. Most tuners run the car more aggressive than Weistec and end up having it run too lean.
I recommend the 60mm pulley on the 3.0 liter. Also, definitely recommend and ice tank and a 50:50 mix of water/meth injection for cooling. Also a small blend of e85 in the tank will do wonders for timing and a bump in octane. I’d say I wouldn’t run more than e30-e40 blend which would be 5-7 gallons and the rest with 93 pump gas.
Also, look into FI Chillers. Another great cooling option.
With all these upgrades your car should be a consistent 650whp car pull after pull
Old May 28, 2019 | 09:15 PM
mr747's Avatar
c63
Go with a full custom tune 100% do a proper tune on 93 ron do not mix E85 blend as your fuel system will already be on limit with 60mm pulley and custom tune
If you want to run e85 you need a full fuel system upgrade
If you go with MS109 make sure its definitely a custom tune as you will get the full benefits
Old May 29, 2019 | 10:28 AM
YYCStage3's Avatar
Thanks for the info. I've spent lots of timing researching, but unfortunately there are lots of conflicting opinions out there. There are a few guys in Australia running ET's in the 9's with the Stage 3/60mm pulley, 250cc/min water meth and the ice tank. They all claim you need MS109 to be safe with the higher boost levels from the smaller pulley, but some feedback points towards not needing additional tuning as its mostly just additional cooling and a bump in effective Octane.
WHP #'s claim to be 700-740, which if legit, would be very impressive for that car.
Old May 31, 2019 | 02:09 PM
J0HN_R1's Avatar
'19 4runner TRD / '12 C63 AMG
If you're in YYC, I'd love to meet up and check out your car sometime...
Hopefully you can find somewhere to do a custom tune, have you tried Davenport ?
Ever go to Euro Cars & Coffee @ the Cardel Center in Quarry Park on Tuesdays, between 6-8 pm ?
Cheers !
Old Jun 3, 2019 | 06:25 AM
go team's Avatar
2012 C63, GL63, 1989 300CE
In for a YYC meet
Old Jun 3, 2019 | 07:09 PM
gzim335's Avatar
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
THIS COULDNT BE ANYMORE MISLEADING....
YOUR GENERIC KNOWLEDGE ABOUT BLOWN CARS DONT APPLY ON THIS PLATFORM.
60MM PULLEY SHOULD NOT BE RUN WITH ANYTHING BUT RACEGAS UNLESS YOU HAVE A FUEL SYSTEM UPGRADE PUMPS LINES INJECTORS ETC THAN YOU COULD RUN E.
Old Jun 3, 2019 | 07:25 PM
PeterA90's Avatar
c63
Relax Jimmy,
I know plenty about this platform. I’ll be nice unlike BLK 🤣
Old Jun 4, 2019 | 12:36 PM
YYCStage3's Avatar
I'm away lots for work, but I've been trying to make it to one of the Cars and Coffee events - hopefully soon.
Davenport does well at domestic stuff - Camaros, CTSV's, Hellcats etc. I don't think id want them trying to tune my car - just my own two cents, I'm not sure how much experience they have with the M156 and Weistec systems.
Eurocharged have done a number of cars, but the closest location is TO, and I'd ultimately like to get some Dyno tuning done, not just a ECU re-flash.
Old Jun 21, 2021 | 05:37 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
hello,
as time has passed I'm sure you may have already found your answer. if not I do want to let you know that we have tuned quite a few supercharged setups with only positive results. feel free to reach out for further information if you haven't already found a solution.
Thanks!
Barry
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
