C63 AMG (W204) 2008 - 2015
Parking break squeal after rear pad change?
Old Jul 8, 2019 | 04:52 PM
LifeIsStout's Avatar
2013 C63 AMG
Edit "fun with spelling, I messed up the title, should be Brake"
Hi Everyone,
I have a 2013 non P31 coupe, I recently did a full brake pad change. I'm super happy with the results (changed out the type of pads, no more squealing from that part). What I am now running into is an issue with what I believe is the parking brake. At very low speeds, or from a standstill I will sometimes here a rhythmic squeal from the rear brakes. I also have the 'parking brake engaged' warning when pulling away intermittently, if I grab on the handle and pull a few times it will go away with no issue. I don't set the parking brake at all, just put the car in park.
So my thought is that after changing the pads, since the new pads are thicker, the car is putting too much pressure on the rear pads, engaging the 'parking brake' and I am unsure how to reset that, or if there is a procedure for doing so.
Any ideas would be super helpful!
Old Jul 9, 2019 | 12:29 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
you said full brake job...so you changed your rotors also?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jul 9, 2019 | 12:57 PM
2013 C63 AMG
Hey Barry,
Sorry I should clarify. I changed pads on all 4 corners. I had the rotors checked (they only have 30K) and they were all within spec, so I had them resurfaced.
One other thing to note is that the noise goes away after about 10-20 mph. And when looking at my dash, that's about when the P indicator goes off on the dash.
Old Jul 9, 2019 | 01:35 PM
hachiroku's Avatar
SPONSOR
check/inspect and adjust your ebrake/parking brake. seems like its dragging. ebrake/parking brake should be a drum pad inside the rear rotor.
__________________
-BARRY
Old Jul 9, 2019 | 01:43 PM
2013 C63 AMG
That's what I want to do, but I can't seem to find a guide/instructions
