C63 AMG (W204) 2008 - 2015
M156 Aluminum intake Tubes!
Old Jun 30, 2020 | 07:49 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Originally Posted by 831amg
I had a conversation with a seasoned Mercedes tech about these tubes, he told me Mercedes has plastic tubes for lots of reasons a couple of them being:
1. If you get in a minor front end collision, it won’t be so minor anymore once the tubes press back and wreck the top of your power plant, The plastic OEM tubes have a folding section midway up the tube.
2. It adds a considerable amount of heat in your engine bay towards the front end which will make you coolant lines overtime more brittle and also plastic parts and connections need to be replaced more often. So basically your paying for your car to be ****ed up easier and more often, not a bad way to blow 300 bucks. Thanks VRP!! Great idea!!! It was my fault for not talking to an experienced AMG tech before making this purchase. Good thing I never got into an accident with these tubes on or it would be a Lawsuit against vrp. I suggest to VRP to cease/desist this product or it will be a lawsuit.
Seriously, next you are going to tell me the intake spacers are a waste of money too - so much for all the mods I was going to buy!
Old Jun 30, 2020 | 07:57 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Now you can spend it on beer!
Old Jun 30, 2020 | 10:01 PM
Top Answer: 1
So much a better use!
Old Jul 1, 2020 | 04:14 AM
831amg's Avatar
2009 C63
Intake spacers
Go ahead, each their own, there’s better things to spend your money on than these hideous pointless dress ups. Dyno results don’t lie
Old Jul 1, 2020 | 04:24 AM
831amg's Avatar
2009 C63
The intake ROW inserts if you get them to fit and they didn’t 3D print it lopsided or warped they do show a power gain at higher rpm’s. Also possibly a little better on fuel economy. Allot more responsive on the throttle. I haven’t tried the intake spacers and I’m not planning on committing any more atrocities on my engine. I’m not trying to shut VRP down just save you guys the trouble and direct your money towards something different. There are better things to spend on like Pipercross foam racing air filters, or a $800 weistech ecu flash.
https://www.ebay.com/itm/MB1-18X9-5-....m46890.l49293
https://www.ebay.com/itm/Pipercross-....m46890.l49293
Old Jul 1, 2020 | 04:33 AM
831amg's Avatar
2009 C63
Another cheap mod
Here’s another cheap mod. You read the thread about putting an e63 intake Y pipe on your c63. That’s great, but what to do with your vacuum hose? You get one of these bad boys with a pressure gauge. This is not just a performance improvement but a dress up option as well. They look tight. You can run it in front of your coolant reserve, or to be safe, by the Engine bay fuse box. The less stuff under the hood forward of moving engine parts the better, remember that.
https://www.summitracing.com/parts/c...CABEgK8HfD_BwE
Old Jul 1, 2020 | 07:21 AM
  #32
Top Answer: 1
I think you guys missed my humor, was never going to put any of this stuff on my car, was always planning to just drive the hell out of my car as it is and then spend the money on beer for the weekend!
Old Dec 8, 2020 | 01:20 PM
  #33
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
In stock! Use code MBWORLD2020 for an exclusive discount!
>>> shop here! <<<
Old Dec 18, 2020 | 06:13 PM
  #34
SPONSOR
E55 C63
Alright first, If youre in a front end collision that's pushing your front end back enough to damage your tubes you already need any entire front clip. Worst thing that would happen with our tubes is they would come apart at the couplers, these are 3 seperate pieces connected with silicone on each side. also, there is no "crash fold" in the factory plastic tubes., They crush, They are plastic. Very thin plastic. No "Fold": Needed.
Point number 2, there is absolutely 0 chance these are causing your coolant lines and plastic parts to become more brittle. First, These are not touching anything other than the silicone couplers, The couplers do not conduct heat. You are talking about radiant heat. There is plenty of that coming off of the engine, These tubes will not effect either the lines or the plastic. The air isnt spending enough time in the tubes to be heated up. The tubes increase airflow from a 2.5" inlet to a 3.5" inlet, Remember the front ducts are 5".
These are currently our #1 selling m156 product. You are perfectly fine keeping your stock plastic tubes But don't spread misinformation. Remember, a Mercedes tech is a mechanic, Not an engineer, Instead of claiming this person as an expert lets say "A guy gave me his best guess as to why Mercedes used plastic tubes (and disregard cost completely)".
Carbon tubes are coming soon!
Old Dec 19, 2020 | 04:53 AM
  #35
HLG600's Avatar
2009 SL63 AMG
ETA?
Old Jan 7, 2021 | 02:05 PM
  #36
SPONSOR
E55 C63
Out with the old plastic factory tubes, and in with VRP high quality aluminum tubes!
>> shop here! <<
Old Jan 29, 2021 | 01:04 PM
  #37
SPONSOR
E55 C63
Clean up your engine bay easily with our intake tubes!
Old Feb 25, 2021 | 08:42 PM
  #38
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
>> shop here! <<
Check out the size and flow characteristic differences. Sounds like another negative out there. Seems like poor performance based choice. I’m looking for a fast girl first, not pretty. In this case like many others, that gloss comes with high negative return.
Old Jun 15, 2023 | 03:16 PM
  #39
SPONSOR
E55 C63
Use code MBWORLD2023 for an exclusive discount!
