M156 Aluminum intake Tubes!
Enjoy a new and improved engine bay appearance upon installation of this upgrade!
Features:
- Adapter pieces are printed in Carbon fiber / Nylon Composite.
- Aluminum Tubes
- High Quality 2″ Couplers
True Aluminum holds more heat, Howeer, If you believe this will effect your intake temps in any way you are incorrect. There air is moving much to quickly through these tubes to pickup any radiated heat from this tiny section of tubes. Also the internal volume of air is exponentially larger than the area of interior surface contact.
You should make these using thermo-plastic materials, and skip the couplings. Design a larger volume intake system that start at the grill and slips onto the airbox.
With ours respectively 3", or 3.5"
The aluminum portion of this tube again can be Powder Coated, Ceramic Coated, or exchanged for Carbon Fiber Tube which will help prevent heat transfer.
The custom adapters included are Carbon Fiber Nylon Composites. Both to the airbox, and to the Grill duct.
What I am explaining to you is however "Heat soaked" These tubes get that heat will not transfer a significant amount of heat into the intake system, and therefore will not noticeably effect intake temperatures.
This product is designed to increase volume. Which it does effectively
Thermal dynamics 101...
Either way, this is NOT a power increase modification. it has laready been proven that the OEM intake snorkles are NOT restrictive.
1. If you get in a minor front end collision, it won’t be so minor anymore once the tubes press back and wreck the top of your power plant, The plastic OEM tubes have a folding section midway up the tube.
2. It adds a considerable amount of heat in your engine bay towards the front end which will make you coolant lines overtime more brittle and also plastic parts and connections need to be replaced more often. So basically your paying for your car to be ****ed up easier and more often, not a bad way to blow 300 bucks. Thanks VRP!! Great idea!!! It was my fault for not talking to an experienced AMG tech before making this purchase.
