Free hp mod
When the E63 / ML63 accumulator purchased on eBay arrives, I'll poke around and see if there's an OE-style mounting location.
In the meantime, am I missing something or does this part just function like a basic vacuum canister?
What I'm referring to (would need to measure & compare volume to OE though):
https://www.jegs.com/i/JEGS/555/6301...2/-1#reviewTab
the renntech intake is the best for N/A application. It’s one piece and large continuing runner into the larger volume y pipe.
been proven by dodger and Blk...
Realistically though, ROW air box lids, Weistec filters and a larger OE Y-Pipe (which is where the RT intake actually changes things) will yield 80+% of the result at < 20% of the cost.
Thank you for the advice on the E63 y intake pipe and vacuum accumulator. I just installed it today. I don’t think I can feel the difference, but just by the look, it does seem that there will be more air flow into the intake.
Where did you locate your vacuum accumulator?
Thinking of doing same can pick up parts for AU$150.
Im looking at installing this bigger Y-Pipe on my C63. But ive got a few questions.
Do you need to run the OEM vaccume canister? or can you just block it off?
Has anyone else done this before?
The style of canister I referenced back in 2020 was way too large to fit anywhere inside the engine bay, so I returned it.
I found this , which has much more manageable dimensions.
What's unclear to me, however, is what kind of an impact a larger-than-factory reservoir will have on operation (if any).
With the N54 canister, it has two nipples (one at each end) how would you plum this up?
I found this Ford canister as a potential alternate, which has much more manageable dimensions.
Sold my RENNtech intake (first version) earlier this year and am debating between returning to ROW lids with the larger Y pipe (at which point I'd test the Ford reservoir out), trying out the BlackBoost intake (there's some data out but ideally I'd like to see a bit more before buying) or waiting for RENNtech to re-issue their intake (latest version, which I understand has a measurable improvement over the one I had).
