C63 AMG (W204) 2008 - 2015
Leaking injector noise
Old Aug 14, 2019 | 08:22 AM
kkkk's Avatar
W204 C63 Estate
Do leaking injectors make a noise when the ignition is on and the fuel rail is primed?
I have a constant "drip drip drip " noise from the injector area, much like a tap dripping water.
If I power the car off completely, the noise stops. Once I prime the car again, the noise starts again.
If this indeed could be the injector dripping, then I may have solved my misfire issue.
Old Aug 14, 2019 | 10:54 AM
chrisridebike8's Avatar
'10 C63
easy way to check is to pull the rail and see if it leaks. mine didn't make noise when mine leaked. how are your oil temps? stable or ALL over the place? many people see oil temps rapidly drop and jump around with leaky injectors.
Old Aug 15, 2019 | 07:19 AM
kkkk's Avatar
W204 C63 Estate
Oil temps seem fine at about 100deg C
