New Billet camshaft for 156/159 video by Tasos
labor shouldnt be much more than headers either honestly you don’t need to pull the heads or anything to do cams... the tubing is apparently a biatch but I haven’t tuned a m156 so can’t confirm that.
Vrp you have a video you said of the clk with your cams, where can we view it? Do you have a dyno with it ?
https://www.vrpspeed.com/product/vrp156camshafts/
I for 1 would not be running cams if they werent tried and tested and verified on the dyno
You must have good customers for them to be running untested cams
Scary
Our initial Camshaft offering was a Factory Camshaft with Added Lift. However its other Benefit is being Hard welded giving it a durability advantage over factory camshafts.
@mr747 Does your Fear have any basis? or just the Idea that untested cams means engine failure? How do you think cams get tested? on a bench? Yes, we have Thousands of Loyal customers, some happily torture test our products in exchange for discounts and to progress the platform. the 55 Community is a bad *** group. The 63 156 guys seem to just complain.
I have considered pulling all of our 156 development projects Including the twin turbo kit and putting our resources into more 157 mods.Try being a little less cynical and a little more productive. Constructive conversation will get everyone a lot further than skeptical negativity. We have our first set of ported heads going on an e63 in the next month aswell.
Yeah, I think for lots of sets to sell, aftermarket cams for this platform need to show improvement in power from simply just dropping them in and then more gains, once tuned. All of the associated install costs are off-putting for most M156 owners and then having to roll the dice on a custom cam tune is a bit meh and only for the die hard fans...of which how many are really out there for this platform now?
Truthfully not many, This is what is really hurting the 156 platform. We sell cams for 55k cars on a weekly basis. That platform has exploded. and everyone wants every HP possible. But we are working on a few things that will drop costs for 156 owners, and hopefully spark some deeper interest.
Any sound clips with them idling and revving.
Something like the scoops on the e55 but bigger and have it like a built intake to go from the front radiator to the air boxes.
There is plenty of room there if we take the top plastic off the top of the radiator.
I forgot to take a pic of the dyno screen when i was at Eurocharged Canada. I asked them to send me the file.
Dadsc63’s cams had .500 lift that would severely affect the stock idle. Mhp had 3 different grinds. Even weistec said that the cams that make power are for of a race car and more of tuning headache. I don’t mind the tuning part since I’m using HPTuners like you suggested.
The kleemann cams are sls style grind. I have email to confirm if you’d like to see.
