C63 AMG (W204) 2008 - 2015
New Billet camshaft for 156/159 video by Tasos
Old Aug 21, 2019 | 02:27 PM
  #51
Kriston's Avatar
C63 AMG
I was wondering why you decided to sell the Renntechs and looking at these other ones.
Originally Posted by Texas E63
haha - I still regret selling those but glad they found a great home !
E
Old Aug 21, 2019 | 03:15 PM
  #52
swedepat's Avatar
2011 C63 AMG, 589hp
Originally Posted by go team
If it solves premature cam lobe wear and lifter failures, then I’m sold. Its compatibility with FI will just be bonus.
Sadly enough they will probably accelerate the wear.
There are billett cams for other engines and it wears the buckets hard.
Cams need to be coated with some slippery coating.
Old Aug 21, 2019 | 03:50 PM
  #53
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Exactly. Harder cams equals faster wearing buckets. If you do this you’re getting the SLS Black Series friction-coated buckets and springs at the very least. Are billet cams “drop in”? Sure, if you want to tear it apart again in 5k miles to do the lifters.
Old Aug 21, 2019 | 05:17 PM
  #54
go team's Avatar
2012 C63, GL63, 1989 300CE
You never (shouldn’t) do cams without the lifters because the surfaces mate to each other. In other words. Ceramic coated lifters.
In the M156 the issue isn’t just the cams it’s a combination of the lifters, cam adjusters, AND cams. So do all and like it’s been mentioned if you open the head up you need to replace gaskets and the adjacent parts like bolts and whatnot. Some bolts are TTY! I will agree to do it properly it would cost 10k at minimum. That also depends on how much the gulf-performance cams cost if you go that route.
if you work on it yourself you’ll need the special timing tools and knock on wood you don’t screw that up and end up with a larger bill.
Old Aug 25, 2019 | 10:04 PM
  #55
richiemiami's Avatar
w140 coupe 1999
all these "tuners" love the supercharged & turbo motors for with little more than adding boost you make 100hp even more. The M156 motors were the best mercedes could do yes maybe eeking out a few more horsepower from dry sumps etc.
so if you think there is going to be a cheap route of increasing your hp on a M156 it's never going to happen. Yes you might have a supercharger, longtube headers and throtle bodies to get 600 - 650 the difference is that none of the other motors will never have the M156 sound
Old Aug 26, 2019 | 02:21 AM
  #56
swedepat's Avatar
2011 C63 AMG, 589hp
Trust me, i know about all that.
But billetcams are made from non 'selflubricating' steele. and thereby wear the buckets harder, or if unlucky it wears the cams faster.
Seen it often in other engines.
billetcams are good in the m113 engine thou, due to roller rockers.
Old Aug 26, 2019 | 09:28 AM
  #57
go team's Avatar
If you do go with the route I’ve mentioned, the hope and goal is that itll last way longer compared to the stockers.
Old Aug 27, 2019 | 01:28 PM
  #58
BalanBro's Avatar
2012 C63 P31 Sedan
Anti friction coatings are used extensively to reduce wear, and there is no reason they couldn't be used on billet steel. Newer DLC (Diamond Like Carbon) coatings were developed specifically for the purpose of reducing friction and wear in applications where high pressures between sliding metal surfaces are encountered. Wouldn't be surprised if that was the coating used on the Black Series M159 buckets with the "black" coating.
The low friction properties would reduce wear on both surfaces, even the uncoated one, because friction will be significantly reduced. I definitely would at least go for the SLS Black Series buckets if I were to drop the coin on these camshafts.
Old Sep 12, 2019 | 03:41 PM
  #59
BLKROKT's Avatar
Old Sep 12, 2019 | 04:10 PM
  #60
brad65ford's Avatar
2020GLC63
Love his videos
Old Sep 12, 2019 | 04:15 PM
  #61
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
i want my 10 minutes back...straight filler episode right there.
Old Sep 12, 2019 | 09:40 PM
  #62
go team's Avatar
That video was a bit wasteful
Old Sep 12, 2019 | 10:15 PM
  #63
Crya's Avatar
2009 C63 P30
Kinda but this and his IM vid inspire me to want to try and do 82 TBs on my own. He makes it look easy.
Old Sep 12, 2019 | 10:29 PM
  #64
skratch77's Avatar
2005 E55
Its honestly really easy to do.
Old Sep 15, 2019 | 03:52 PM
  #65
BLKROKT's Avatar
Old Sep 22, 2019 | 08:46 PM
  #66
BLKROKT's Avatar
slowest reveal ever
Old Sep 22, 2019 | 09:25 PM
  #67
Phil1305's Avatar
C63
Originally Posted by BLKROKT
https://youtu.be/PcEFvoNEoqE
slowest reveal ever
I agree!!!!
I like how hes fully documenting everything with the car, as in maintenance and all specs etc. Hes not just trying to sell cams. Hes trying to show what these cams will do given all other variables the same. Which is the way it should be.
Old Sep 23, 2019 | 11:35 AM
  #68
PeterA90's Avatar
c63
At least he documents/ tests product unlike some vendors...
Old Sep 23, 2019 | 02:12 PM
  #69
skratch77's Avatar
2005 E55
Yeah I dont get why some people are hating. This is by far the best review to test out cams and making the stock car run as best as it can.
He could of just put the car on the dyno with bad adjusters and worn cams and been done with it but chose to fix it first.
Old Sep 23, 2019 | 02:58 PM
  #70
BLKROKT's Avatar
I’m not hating, 0%. Just saying that he could have had a car properly baseline tested and up and running on the new cams in 4-5 days like some of his other projects, rather than 4-5 weeks (so far).... I’m dying to see what these things do. He knows exactly what he’s doing, the demand for these are gonna be through the roof when he’s done. His phone will be ringing off the hook.
Old Sep 25, 2019 | 05:47 PM
  #71
gzim335's Avatar
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
We got a new video,what a waste of time with that pos 63 he choose
Old Sep 25, 2019 | 07:24 PM
  #72
mr747's Avatar
c63
lmaooooo his fuming
Old Sep 25, 2019 | 07:40 PM
  #73
deadlyvt's Avatar
2010 C63 AMG
No kidding unreal how many things are wrong and or needing replacement now or very soon
Old Sep 25, 2019 | 07:44 PM
  #74
BLKROKT's Avatar
I bet these cams will make 30whp
Old Sep 25, 2019 | 08:20 PM
  #75
mr747's Avatar
c63
yep 100%
