C63 AMG (W204) 2008 - 2015
C63 black series N/A BEAST
Old Aug 26, 2019 | 09:03 PM
gzim335's Avatar
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
Finally dialed in the car
ARH & XPIPE
RENNTECH AIRBOX
STOCK INJECTORS
FULL E85 (pump e85)
WEIGHT REDUCTION
STOCK WHEELS PSS TIRES
8.1 60-130
REDOING THE EXHAUST THIS WEEK AT ARH FULL 3INCH REAR.
CAR IS GINTANI TUNED ON FULL E85
LOGGING WITH DASHDAQ SHORT TERM FUEL TRIM IN CHECK.
NO FLEX FUEL OR INJECTORS NEEDED HERE.
Old Aug 27, 2019 | 04:09 AM
MrkiC63's Avatar
MB C63 AMG
Not valid run ... video dosent show downhill.
Old Aug 27, 2019 | 08:30 AM
gzim335's Avatar
Most of the runs are in this range.
Old Aug 27, 2019 | 08:53 AM
PeterA90's Avatar
c63
Strong car jimmy 👍🏻
Old Aug 28, 2019 | 01:04 AM
SatelliteMan's Avatar
2009 C63 AMG Sedan
What do you mean no flex fuel is needed here? You stated you are running E85, just without a kit? I didn't know you can do that.
Old Aug 28, 2019 | 06:43 AM
MrkiC63's Avatar
MB C63 AMG
Thats about 7.6 seconds from 100-200kmh ... that is really fasts for a NA C63. About 1 second faster then stock.
Old Aug 28, 2019 | 08:33 AM
skratch77's Avatar
2005 E55
You dont need a kit if your tuned for e85
Old Aug 28, 2019 | 10:17 AM
BalanBro's Avatar
2012 C63 P31 Sedan
True, but you need a good source if you're running without a sensor. Unfortunately most of the pump E85 in the US varies wildly in ethanol content. The flex fuel sensor accommodates fueling as needed, although only a tune can take advantage of more aggressive timing.
Old Aug 28, 2019 | 10:39 AM
PeterA90's Avatar
c63
Full e85 can be run without a flex fuel kit but now the car isn’t flex. That’s the whole point behind them. Car now is married to e85. And yes now you have to monitor ethanol content to accommodate timing. More of a headache imo. Duty bias on the stock injectors are probably pinned at 95% at WOT. When the Bosch ecu sees that it would actually pull timing since it thinks it’s running out of fuel and you’d lose power. With every action there’s a reaction on these cars. 1+1 never equals 2.
Old Aug 28, 2019 | 11:10 AM
skratch77's Avatar
2005 E55
I've had best results on oe 104 map with 5 gallons ms109/ms100 and half gallon c85. Car runs insanely well.
Good luck with the people running 630cc injectors and a flex fuel kit without tuning.
There is no freaking way the car will run well on that setup.it will use so much fuel. My trims were minus 40 on both banks with only a mix of 40% ethanol.
Old Aug 28, 2019 | 11:15 AM
PeterA90's Avatar
c63
630 cc injectors on n/a are even too large while tuned
Vrp sells the wrong injectors. What do you expect when he doesn’t test ****.
Old Aug 28, 2019 | 06:39 PM
gzim335's Avatar
Old Aug 28, 2019 | 06:40 PM
gzim335's Avatar
They Deff not pinned at 95% i log my car and it’s keeping up with e85 no issue,it’s not running out of fuel or pulling timing as you can see car is performing hitting 37 degrees of timing at redline
Old Aug 28, 2019 | 06:55 PM
PeterA90's Avatar
c63
37 degrees of timing lol hopefully that’s a typo. The setup your running is on the ragged edge of n/a and what stock components can put out. Never said the car isn’t performing.
Old Aug 28, 2019 | 07:02 PM
gzim335's Avatar
Yea on the edge it is.
Old Aug 28, 2019 | 07:54 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
the 997 turbo injectors that many use when i'm on 91 octane at MAX i've seen -30 and that was at idle me holding the brake pedal. upon driving that moved to the 20's as usual.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 29, 2019 | 06:37 AM
Celicasaur's Avatar
W212 - E63 AMG
ARH & XPIPE
RENNTECH AIRBOX
STOCK INJECTORS
FULL E85 (pump e85)
WEIGHT REDUCTION
8.1 60-130
https://youtu.be/68saj5yi4xc
Credit where it's due....that's very fast indeed. You probably can get that time down even further by starting the run in 2nd and revving to 7500 or 7800 if you're feeling brave. That way, you get into third with more intertia and the time from 60 - ~70 will be faster than in third....mind you, I'm not accounting for the gear shift time, so who knows. Either way, that's running hella stout. More impressive that you're on stock wheels and not 16s....well done man.
Also.....37 degree's!?
Old Aug 29, 2019 | 09:38 AM
skratch77's Avatar
2005 E55
Car is running beast mode man. Ate you on 82mm tbs yet? Also do you mind posting your maf readings?
Old Aug 29, 2019 | 11:13 AM
gzim335's Avatar
Still on stock Tb,hopefully i can work out a deal with vrp for tb and crank pulley to squeeze out as much as i can from my setup
got a track rental coming up on the 24th let’s see what it does.
Old Aug 29, 2019 | 02:29 PM
Texas E63's Avatar
Built 2008 G55 & one big 80 Series LandCruiser !
Congrats - great #'s....... Shardul's underdrive kit and billet pulley's worked really well in my car - worth doing it all while you're in there....
I sure wish VRP would post some support backup info for their TB's....... I'd like the 85mm setup and think given I'm running E85 all the time that it would be a decent gain but...... have yet to see an actual set installed by a member much less dyno or documents...
E
Old Aug 29, 2019 | 03:55 PM
gzim335's Avatar
E
I offered to install and test his parts with before and after dynojet runs but nothing yet.
