C63 AMG (W204) 2008 - 2015
09 C63 won't start
Old Sep 2, 2019 | 02:32 PM
C55_AZ's Avatar
2005 C55 AMG (not stock) 2009 C63 AMG (Stock)
09 C63 won't start
Drove the car last night with no issues. Went to start it this morning and it would not start. Radio and stuff still comes on, but car won't turn over. I can hear a couple ticks when I try. Any ideas? Steering column?
Old Sep 2, 2019 | 03:42 PM
Ludedude's Avatar
2014 C63 Coupe
Ticks "usually" mean a dead battery. You can have enough juice for the radio etc. but not enough to crank the engine. You could check the connections at the battery, make sure they're tight. Check fuses etc.
Old Sep 2, 2019 | 03:49 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
It's not ESL if radio comes on
Old Sep 2, 2019 | 03:58 PM
Bonesxxx's Avatar
2016 GTs, 2014 C63 AMG and 2014 C350 Sport (wife's car, she thinks it's an AMG - shhhhhh)
Always start with the easy stuff first. Sounds like a low battery to me. Clicks are the tell-tale. I've heard that even when giving someone a jump -- you have to leave the cables hooked up for a good 10-15 minutes until the battery has enough juice to turn the motor.
Next candidate is solenoid or loose connection somewhere.
Old Sep 3, 2019 | 02:54 AM
C55_AZ's Avatar
forgot to mention, steering wheel is locked as well
Old Sep 3, 2019 | 11:48 AM
chrisridebike8's Avatar
'10 C63
Wait, does the radio come on when you turn the key? Or does it come on if you manually turn it on. If you turn the key and the radio comes on, it’s not the ESL. If you turn the key and NOTHING comes on (dash, radio, etc) and the steering wheel stays locked, it’s definitely the ESL.
Old Sep 3, 2019 | 12:33 PM
C55_AZ's Avatar
Radio will come on if I manually do it. So ESL it is.. I have only had the car for a month and the luck is already starting lol
Old Sep 3, 2019 | 12:44 PM
C55_AZ's Avatar
Had it towed to the dealer this morning, it was in fact the ESL. Thank you all for the replies!
Old Sep 3, 2019 | 01:52 PM
'10 C63
Been there. Mine died at work and I had to get 2 Navy Captains go move their cars so the flatbed could get my car. Haha.
Old Sep 3, 2019 | 02:10 PM
Drift1492's Avatar
Infiniti
Don’t pay the dealership if you’re mechanically inclined and have time. Fixed mine for less than $400 total. Dealership wanted a lot more. Don’t remember the quote but it was between $1500 and $2000.
Old Sep 3, 2019 | 02:48 PM
Bonesxxx's Avatar
I've read ESL is another failure prone MB part... did they make any changes for the FL years or is it the same?
Just curious.
Old Sep 3, 2019 | 05:45 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Try to jump it first. If it doesn’t work esp failure most likely it won’t start unless the steering wheel unlocks.
Old Sep 4, 2019 | 09:48 PM
Adi-Benz's Avatar
I'm assuming he's already getting it fixed, I replaced the motor myself and done for $20
