Thoughts on my cam wear
If we agree that idle = bad cam wear, then its likely that the severe cam wear observed on low kms cars is a result of too much idling - makes sense to me and one of the reasons why I decided against installing a remote starter kit on my vehicle.
Another thing I have always wondered is whether Tasos is right in running 10w/60 oil on these engines - I know some people reckon its crazy to run such a high viscous oil...BUT if the ideas is to coat the upper engine parts thoroughly between drives (say if the car is a daily driver) then maybe a thicker viscosity is better at reducing valve train wear on startup? Makes sense to me...but I would be interested to see the numbers.
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
But the general consensus is 0w30 is too thin for our engines and MB used to use 0w40 M1 and now use 5w40 M1 to try and mitigate lifter bleed down problems with the M156.
There are some really good threads on this topic and awesome (detailed) posts by some of the more experienced members..i luv reading this stuff
..links below.https://mbworld.org/forums/c63-amg-w...0w40-5w40.html
https://mbworld.org/forums/c63-amg-w...c-229-5-a.html
https://mbworld.org/forums/c63-amg-w...-question.html
Note the number 2 next to the 229.5 dot for some engines including M156.
Point 2 at the bottom of the page reads:
Restriction: Only SAE 0W-40 und SAE 5W-40 engine oils are allowed !
I‘m not a engineer but it shouldnt be a rocket science to solve this problem.
Good Find
