C63 AMG (W204) 2008 - 2015
Random noise from engine
Old Oct 18, 2019 | 01:35 AM
JM63AMG's Avatar
2011 c63 AMG
Hearing this rumbling like if a something is loose or jinggling around.
Old Oct 18, 2019 | 09:47 AM
Bonesxxx's Avatar
2016 GTs, 2014 C63 AMG and 2014 C350 Sport (wife's car, she thinks it's an AMG - shhhhhh)
Sounds bad enough to me to remove the valve covers (at a minimum) and take a gander before something grenades on you. I wouldn't drive it until it's diagnosed properly.
Sounds like a bad lifter. Is it throwing a code?
Old Oct 18, 2019 | 10:29 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
You need to replace your pulleys asap. That's a pulley bearing about to grenade.
Old Oct 18, 2019 | 10:51 AM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Pulleys!
Old Oct 18, 2019 | 11:36 AM
Turkish05's Avatar
C63 soon
I think one of the pulleys too!
Old Oct 18, 2019 | 12:32 PM
JM63AMG's Avatar
2011 c63 AMG
That is what im thinking it was. And it is not throwing any codes at all. So when im on the throttle the noise goes away but when i come to a stop in comes back. Feels like the belt or pulley need to be changed.
Old Oct 18, 2019 | 01:45 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Sounds like bad pulleys to me.
Old Oct 18, 2019 | 03:24 PM
JM63AMG's Avatar
2011 c63 AMG
No codes at all. When i hit the throttle it stops but if i come to a light it will start. It looks like a pulley is moving back and forth.
Old Oct 20, 2019 | 01:15 AM
JM63AMG's Avatar
2011 c63 AMG
Took the car to a shop they told me its one of the pulleys they even put pressure to show it was and the noise stopped they gave me an price of $300 for all new pulleys. So i wanted a 2nd opinion and took it to mercedes dealership they said it was an exhaust cam. Not sure what that is. They also said all the pulleys need replacing and timing chain. The price $4900!!.
Old Oct 20, 2019 | 07:54 PM
curt.r's Avatar
2013 P31 C63 Sedan
Originally Posted by JM63AMG
So i wanted a 2nd opinion and took it to mercedes stealership they said it was an exhaust cam. Not sure what that is. They also said all the pulleys need replacing and timing chain. The price $4900!!.
Fixed that typo for ya
