C63 AMG (W204) 2008 - 2015
Who's in helping develop 82mm throttle body stacks?
Old May 14, 2020 | 07:16 PM
  #51
SROC276's Avatar
2010 C63 P31 AMG
Originally Posted by VictoryRoadPerformance
3d Test print for the aluminum Press on stacks.
Looks good..slightly larger than 82mm then on your design vs oe style stack?
Old May 15, 2020 | 10:52 AM
  #52
HLG600's Avatar
2009 SL63 AMG
Are stacks being developed for both the 82mm and 85mm throttle bodies?
Old May 15, 2020 | 12:51 PM
  #53
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
one stack to rule them all, The stack will be built for 85mm but will be compatible with 82
Old May 15, 2020 | 08:00 PM
  #54
SROC276's Avatar
2010 C63 P31 AMG
Will the throttle body edge/lip (82mm) inside the stack (85mm) be an issue for flow as seen in photo?
Old May 15, 2020 | 10:32 PM
  #55
SPONSOR
E55 C63
<br /><br />There will be an overhang. It wont effect flow.<br />
Edit correction: Posted below, but the ID of the stacks are 85mm.
Old May 16, 2020 | 02:09 PM
  #56
dmd-amg-c63's Avatar
2012 Mercedes C63 AMG
So what’s the timing for availability?
and how much for the complete kit with the stacks?
Old May 16, 2020 | 02:14 PM
  #57
skratch77's Avatar
2005 E55
My stacks have no lip on the inside that will defeat the purpose of the stack. There will be turbulence on vrps stacks.
mine mesh flush with the throttle body.
Old May 17, 2020 | 06:56 AM
  #58
Southways's Avatar
C63 Coupe, 2014, 507
Huh?
Restricting the diameter & creating a sharp undercut in the flow path, but won't effect flow?
Old May 18, 2020 | 01:23 AM
  #59
SROC276's Avatar
2010 C63 P31 AMG
skratch..any issue with material used with heat and degradation? I see you have used a silicon hose to keep it in place. Just wondering about degradation due to heat etc. sent you a pm but not sure if you got it.
Old May 18, 2020 | 01:27 AM
  #60
SROC276's Avatar
2010 C63 P31 AMG
Pm you
Old May 18, 2020 | 01:29 AM
  #61
SROC276's Avatar
2010 C63 P31 AMG
Originally Posted by mbc23k
I have a set of 82mm Renntech Velocity stacks if you are interested.
pmd you
Old May 18, 2020 | 10:37 AM
  #62
SPONSOR
E55 C63
No, The Stacks will have a ID of 85mm at the top. When slipped over the 82mm TB there will be 1.5mm that the stack will not overlap. This is less than if you were to say put a coupler on a throttlebody or a sleeve with a clamp. it will have 0 effect on performance in any way. the Stack will not restrict any flow, it will be larger than the 82s, but exact on the 85s.
Old May 18, 2020 | 10:42 AM
  #63
SPONSOR
E55 C63
You can clearly see a gap in this stack, the press on will sit flush. im sure these work fine, but based on the way these are assembled unless they are glued i can see the stack popping out of the coupler.
Everyone is welcome to buy whatever stack they want, but we are just making them because you all asked.
Target price $175 for the pair of aluminum press on.
Old May 18, 2020 | 10:59 AM
  #64
skratch77's Avatar
2005 E55
There is no gap i just through that on to take a quick picture. they sit flush without anything showing from tb to stack.
I can upload another picture.
What are you using to keep your stacks from falling off the throttle body? Your right people can buy what they want but this is my throttle body thread.
Old May 18, 2020 | 11:42 AM
  #65
skratch77's Avatar
2005 E55
Old May 18, 2020 | 11:51 AM
  #66
skratch77's Avatar
2005 E55
Sorry I missed getting back to you. I had a major tear in my shoulder and spent the day in the er and been in pain for about a week now.
I can still barely move my arm but I'm getting better. I'm using samco hoses for the way to get these on flush. I tried adhesives and glue but that won't hold up. Plus you risk that stuff getting inhaled in your engine.
With the samco hose its on really tight and might actually stay on with out a clamp but on my car im running them with clamps to make sure they stay on..
this plastic is rated for 300 degrees and it won't get anywhere near that temperature in the intake manifold
You guys should see what I'm working on lol let's just say our manifolds bottle neck is having 2 throttle bodies jammed in the middle of it.
I dont know why nobody has made something to move the tbs outside from the manifold yet.
Old May 18, 2020 | 12:43 PM
  #67
SPONSOR
E55 C63
Ours are aluminum and will require a press to push them on. You should use Loctite assembly lubricant when pressing them on, They will be extremely difficult to remove once pressed on.
There will be no more of an edge than pictured here.
Old May 18, 2020 | 12:59 PM
  #68
skratch77's Avatar
2005 E55
There is no edge that is the same tb as picture above at another angle.
Old May 18, 2020 | 07:44 PM
  #69
SROC276's Avatar
2010 C63 P31 AMG
Thanks Skratch! Hope you heal up well and soon.
Old Jun 5, 2020 | 02:23 PM
  #70
SPONSOR
E55 C63
ID is 85mm, No lip for 82s, and flush for 85mm. running aluminum prototypes now
Old Jun 5, 2020 | 02:37 PM
  #71
skratch77's Avatar
2005 E55
I have a set ready to ship if anyone wants a pair!
Old Jun 5, 2020 | 04:54 PM
  #72
MBNRG's Avatar
Thanks, VRP. Would you please post photos of the Stacks on the 82mm?
Old Jun 5, 2020 | 09:25 PM
  #73
SPONSOR
E55 C63
That is an 82
Old Jun 5, 2020 | 09:37 PM
  #74
95gsrturbo's Avatar
2000 Acura NSX, 2012 C63 P31 (gone and not forgotten), 2015 C63 507
Pm'd sir
Old Jun 5, 2020 | 10:58 PM
  #75
MBNRG's Avatar
That is an 82
I like it!
