C63 AMG (W204) 2008 - 2015
CATCH CAN PCV Adapter Fittings
Old 12-12-2019 | 11:46 AM
  #51
c63_alex's Avatar
2012 C63 AMG - 2006 Mitsubishi Evo IX - 1979 Jeep CJ7
I got around and installed these fittings yesterday. While i was there i decided to do the intake manifold gaskets, bolts, pcv valve and clean out the valves.
There wasn’t too much oil in my intake having only 35k miles but the valves were pretty gunked up.
The fittings fit perfectly. I used a 90 degree and a 45 degree push lock for the pcv side of the catch can setup. It’s tight but it works. Car turned on and automatically i can feel better throttle response and it runs more smooth.
anyways thanks again JD for saving me a few hundred bucks on a Weistec setup lol
Mully78 (12-12-2019)
Old 12-12-2019 | 01:15 PM
  #52
BITRBO's Avatar
2001 Audi S4 Sedan (RIP) 2013 P31 W204 C63 (RIP)
Any before shots of your intakes runners & valves? I've got the same mileage so just curious what it may look like in there...
Old 12-12-2019 | 01:28 PM
  #53
c63_alex's Avatar
The one thing i forgot to do was take close up pictures before cleaning. I rushed it and started cleaning right away. If you can zoom into this picture you might be able to see. They were pretty gunked up. The intake manifold runners were nasty as well. Used about 3 cans of brake clean for the whole thing. I sprayed a lot into the valves, scrubbed with towels then used a shop vac to suck up the dirty brake clean from inside
Old 12-12-2019 | 01:45 PM
  #54
BITRBO's Avatar
Ok, thanks! So do intake manifold gaskets tend to go out early on these cars or did you just replace for good measure while you were in there?
Old 12-12-2019 | 01:50 PM
  #55
c63_alex's Avatar
I just replaced it for good measure. The bolts and gaskets were about $35 plus $130 for pcv. Figured since I’m messing with the pcv, might as well replace it with a new one. It wasn’t too hard, there’s some really good write ups on here. Just label every hose you remove and you should be good
Old 12-12-2019 | 03:50 PM
  #56
BITRBO's Avatar
Cool, thanks again
Old 12-13-2019 | 12:12 AM
  #57
jd_hinks's Avatar
2015 C63 AMG Edition 507 coupe, 2017 Range rover sport Auto, 2008 dodge ram 1500 SLT
Originally Posted by VictoryRoadPerformance
These fittings look really great! good job!
Thanks guys appreciate it!
Old 12-13-2019 | 12:16 AM
  #58
jd_hinks's Avatar
Hey Alex.
Glad to hear everything came in! Sorry again bout the tracking #...
Good job on the pics this should help give the guys a visual who aren't 100% bout what these fitting are. Cheers!
Old 12-13-2019 | 12:18 AM
  #59
jd_hinks's Avatar
Hey guys I'm in Thailand for the next 4 weeks I'll be back Jan 9. If anyone wants a set I'll make a list and start sending out once I get back to Canada. Thanks.
Old 12-13-2019 | 01:19 PM
  #60
Phil1305's Avatar
C63
I will surely take a set asap!!
also are they only in red??
Old 12-17-2019 | 07:36 PM
  #61
Prazstar's Avatar
2012 Mercedes Benz C63 AMG P31 W204
Pm sent, thank you
Old 01-20-2020 | 01:27 PM
  #62
jd_hinks's Avatar
Hey Guys,
Glad to hear ur happy with the fittings! Still have a few sets left if anyone interested let me know thanks!
Old 02-05-2020 | 02:21 PM
  #63
jd_hinks's Avatar
Bump!
Old 02-18-2020 | 12:08 PM
  #64
DennisW212's Avatar
2013 E350 4Matic Sport
Hi guys has anybody tried this adaptor fitting on m276 Motor ? I want to see if these can fit also can you please tell me what size are these so can measure if this will fit thanks so much!
Old 03-21-2020 | 07:00 PM
  #65
jd_hinks's Avatar
Hey. Fittings only compatible on M156 motor
Old 03-22-2020 | 12:47 PM
  #66
DennisW212's Avatar
Thanks a lot I already did with out the fittings
Old 04-13-2020 | 09:44 PM
  #67
rbtmak's Avatar
GLS63, R63, Cayenne Turbo & GTC4 Lusso
Do you have anymore if these? Thanks!
Old 04-13-2020 | 09:45 PM
  #68
jd_hinks's Avatar
I do. I'll send you a PM.
Old 04-17-2024 | 10:20 AM
  #69
Lvnloud28's Avatar
C230
I need a set please
Hey Guys,
I would like to purchase the m157 pic billet adaptors for catch can install
Old 05-20-2024 | 10:18 AM
  #70
See63Run's Avatar
2013 C63 (W204)
please let me know if you have another set of these
Quick Reply: CATCH CAN PCV Adapter Fittings
