C63 AMG (W204) 2008 - 2015
Supercharged guys - who’s had their standard gearbox last?
Old Dec 16, 2019 | 11:58 PM
NAPARM's Avatar
C63 AMG
I have a Weistec stage 3 on my pre facelift but it isn’t pushed at all and only making about the same power as a stage 2 (556rwhp).
Who has had similar power and had the standard box last a long time? (More so talking about pre facelift so not MCT box).
Cheers
Old Dec 18, 2019 | 11:52 PM
roadtalontsi's Avatar
10 C six trizzle
good luck that's all i can say. lasted around 30k both times. Im at 60k on round 3. It will drive totally fine, but under full load you'll feel and hear the 2-3 shift sound like it's slipping. Just drive it and fix it when it happens you've got some time. Most dont drive as hard as my car has been through. multiple road course, drift and drag strip events.
Old Dec 18, 2019 | 11:56 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Who builds your transmissions? Do you always have a spare around to minimize downtime? When they go on you, do you just box them up and mail to Weistec or do you have a local guy? I’m trying to figure out the logistics myself. Everyone I’ve shown the clutch packs to around here just runs the other way.
(Yes I realize I can just drive it to Weistec and drop it off now. Still curious.)
Old Dec 19, 2019 | 01:41 AM
NAPARM's Avatar
C63 AMG
30k isn’t too bad if you’re driving hard. How much power you making?
Old Dec 20, 2019 | 08:13 PM
AwdthisC63's Avatar
2011 C63 1998 ML430
Stage 2 stock trans lasted 4 pulls 60-130mph for me. Trans started to slip just after the blower install. Had 38k miles on stock trans at the time. Trans got service every year, typically drive anywhere from 2-5k miles a year With trans upgrade have about 3-4K miles on it. Has been taken abuse good for now, a lot of roll racing and maybe dozen 1/4 mile passes.
Old Dec 21, 2019 | 01:58 AM
10 C six trizzle
Wink
The first time I rebuilt it under warranty myself while at the dealer . At that time I put the Weistec pan and added a second oem transmission cooler with the integrated thermostat. I sent the valve body off to Weistec in hopes that would help prolong its life. It didn't really seem to matter. While apart this time I checked the solenoids upon removal to see if they were clogged at all (none were) and found that one of the mods is to lop off the screen of the primary line pressure feed solenoid. I replaced the solenoid with a new on because that is a trash mod. That's like removing your oil filter because you want better oil pressure lol. WTF. On round 3 I tried something a little different so I can tell you it's not the transmission that came with the car although it is a 722.9 . I'll keep ya'll posted on how it holds up. I rushed to get out to the track for the last day it was open this year and ran an 11.5 at 130mph. Ambient temps around 50, which was way too cold for any street or my toyo R888's to hook like a slick my slicks, which I brought with me but forgot the damn spacers!!! (still made at myself for that) The fastest I'd ever ran mph previously was 127 mph. Mind you this is a full weight, pump gas car, no weight removal bs, had a jack and the spare tire in the back. Full size front tires/wheels. No trickery. 19" hre wheels, akrapovic slip ons and 2pc girodisc rotors front and rear. No trunk tank, no ice. I haven't weighted the vehicle, the scales at the track are always broken when i go. Fastest I've ever ran previously was an 11.2 (don't remember the mph likely 127, maybe slower)
Dyno'd at 538whp / 534wtq on a mustang many years ago.
It's been a solid setup in general and I can't really complain. The only breakdowns or all out failures I've had are a driveshaft snapped where it splines into itself, and 1st gen idler pulleys that only had 1 bearing failed. They since updated with a double bearing setup. It's also eatin 2 or 3 power steering pumps and it's time for another. I definitely need to change the reservoir setup when I replace it.
Im getting ready for a motor build and some major changes so we'll see how this thing holds up.
Old Dec 22, 2019 | 06:08 PM
mr747's Avatar
c63
mine last 10 mins with stage 2 after install
bullet proof lasted me 1 year before another rebuild
this new trans has been good but built with weistec and g63 bits
but built in Australia
Old Dec 22, 2019 | 09:38 PM
gzim335's Avatar
c63 coupe p31weistec stg3 SOLD,2013 C63 BLACK SERIES.
Mct cars stage 3 67mm pulley
i have about 30k between two cars never slipped on either car,never seen drag strip tho only highway pulls etc
Old Aug 7, 2020 | 06:58 PM
Aussie E63's Avatar
2007 E63
Apologies for the necro'ing of the thread, but who did you get to build your trans here in Australia and how much did it come to?
My engine is currently in bits. It needs a piston and a rod - a set of forged pistons and rods is the same as a single rod and single piston from Mercedes! Hence now considering a supercharger install together with a forged build.
I run an '07 E63 with the 7g...and thus am interested in gauging the cost of a 7g build. Or, alternatively, ditching the 7g and retro-fitting in a later MCT box (apparently stronger). However, I wonder if this is even do-able into an early non-MCT factory chassis?
Old Aug 7, 2020 | 07:16 PM
mr747's Avatar
c63
Budget about 10k for built trans to handle 1000 hp
Stick with the 7g trans they work really well when built
Happy for you to pm me my trans was built by International auto haus
Old Aug 7, 2020 | 07:39 PM
Aussie E63's Avatar
2007 E63
PM sent!
Old Aug 7, 2020 | 07:57 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
curious what was done to the transmission? did you upgrade to thicker plates as well as other things?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
