Stripped radiator drain plug and slowly leaking - now what?
I stripped the plastic drain plug and now it is slowly leaking. I am now able to turn it 360°. Which side are you suppose to turn to close the valve, clockwise or counterclockwise? I am not sure what to do with that. Do I have to change the whole radiator itself? It would be a pain...
I searched, without any success.
Thanks!
My last question is: closed, is the plug vertical or horizontal? Does it rotate only 90°? I need to know which side I will have to put my new plug...
