Bad fuel like pinging at light throttle?
![Angry](https://mbworld.org/forums/images/icons/icon8.gif)
Hey all.... Ive got a 13 C63 with about 80k on it. Done plugs, and injectors chasing a weird pinging noise that sounds like bad fuel.. at highway speed in any trans mode while cruising if I lightly accelerate there is a noticeable ping/spark knock. No codes, no misfires, all monitors pass. Factory or bosch parts used only and I only run Chevron 91.. yes Im in Cali. Ive also run 100oct and a few different boosters to try and see if it helps.. It didn't. Any thoughts???
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Did you recently get a tune or change an existing one?
they are “usually” good although sometimes in shipping they get bumped around and the gap can be out. Literally had symptoms like this before on spark plugs I didn’t check and upon checking half of them were out of spec as far as the gap was concerned
2020 E 300 Coupe and 2019 GLS 400
This is from the owner's manual. "A major concern among engine manufacturers is carbon build-up caused by gasoline. Mercedes-Benz recommends only the use of quality gasoline containing additives that prevent the build-up of carbon deposits. After an extended period of using fuels without such additives carbon deposits can build up, especially on the intake valves and in the combustion area, leading to engine performance problems such as:
· Warm-up hesitation
· Unstable idle
· Knocking/pinging
· Misfire
· Power loss"
I had knocking in my E55, was told it is a stuck lifter or rod knock. One bottle of Chevron Techron concentrate and WOT blew a black cloud out the exhaust and I never heard ticking again.
· Unstable idle
· Knocking/pinging
· Misfire
· Power loss"
Received 2,836 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Just regap them dude. No need for new plugs.
And it’s probably just CA gas, it blows. Chevron seems to be the best.
· Unstable idle
· Knocking/pinging
· Misfire
· Power loss"
· Unstable idle
· Knocking/pinging
· Misfire
· Power loss"
Yeah I’ve have had a few additives, boosters and and minor top end cleaning performed. I’m thinking in addition to gapping new plugs appropriately I’ll rebuild the manifold, inspect and clean the intake valves in the head and replace the PCV.
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I've read very good things about Shell's VPower formula for knocking out and keeping away carbon deposits. Had good luck with it myself as well. It's the only fuel I use in my performance vehicles, and will fill up with a tank every once in a while on my non-performance vehicles as well.
SPONSOR
2007 Mercedes E63 AMG
where are you in cali? if northern we could meet up and i'll be able to tell you what the noise is. could be cam adjuster noise as well, but generally that goes away after some time after the engine is run.
pretty rare that a stock engine stock tune will see engine ping/detonation.
ping/detonation sounds like a small metal ball or pebble being shaken inside an aluminum soda can. this occurs when fuel isn't enough or ignition timing is too advanced. generally speaking the computer although may not throw a misfire code, will sense knock or the chance of knock and pull timing accordingly. the Bosch Motronic 9.7 engine control computer utilizes spark plug ion sensing technology to detect inconsistencies within the combustion chamber. essentially sensing knock before knock occurs. utilizing this, the computer will apply timing retard individually to each of the 8 cylinders as it dems fit. this in turn will avoid detonation and chance of actual knock which can destroy your engine.
yeah I’m tracking on the cam and adjuster noise it definitely isn’t that. The engine is timed properly and there is no excessive play in either the exhaust or intake adjusters. The chain has no slack either and when hooked up to a scanner everything checks properly. 0 misfire count.
after plug adjustment and pcv replacement I’ll run a few tanks through
***Update****
Took fuel sample( less then 1/16 of a tank) and noted about 8% Eth. Took out all plugs.... 5 out of 8 were gapped wrong. Only 1 of the 5 were too small the rest were .0041/.0042. Got them all to .039, Full tank of Fresh 91 Chevron and a spirited drive through Mexico showed promising results. The vehicle got to temp faster, the idle was smoother and had less fluctuation, off idle throttle response was better in all trans modes, and best of all.... that damn pinging was gone!
!!Check your gaps!!
!!Check your gaps!!
BiturboSF (02-17-2020)
Same issue here
I was going to post new but found your thread as I have a very similar issue, pinging at light throttle, any driving mode or gear, no codes, no misfires, not tuned. I recently changed out my plugs, cleaned MAF sensors and replaced MAP sensor so I will check the gap on the new ones however it was pinging on the old ones as well, it only happens at max operating temp and does also present with a inconsistent idle speed when in park, moves between 800 and 1200rpm. Mine is an 08 with 140k on it, I only use BP Ultimate 98 RON or Caltex Vortex 98 RON fuel, no different on either fuel, have tried liqui moly fuel additive but it did not improve. Hopefully mine is the gaps as well and I too can enjoy the sound of the M156 and not pinging!
