C63 AMG (W204) 2008 - 2015
Anyone change the thermostat without changing the coolant?
Old Apr 22, 2020 | 02:42 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
Is it possible without making a huge mess? My car has pretty new coolant. The thermostat DIY looks pretty easy and quick, but jacking up the car and draining the coolant will double my working time. Would I lose a bunch of coolant by changing the thermostat? Seems like' it's pretty high on the engine and coolant wouldn't settle there?
Thanks,
Cyrus
Old Apr 22, 2020 | 02:53 PM
deadlyvt's Avatar
2010 C63 AMG
You lose a bit but it’s not that much... but it is pretty easy to drain the couldnt you don’t have to jack the car the drain valve is on the front driver side just loosen it and drain it quick in a container and put it back in when you have the t stat changed.
Old Jun 4, 2020 | 07:33 PM
tasteofpower's Avatar
2011 C63 AMG
im trying to do this now. but the power steering reservoir is in the way and i cant figure how to remove it. any ideas?
Old Jun 4, 2020 | 08:53 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
https://manualzz.com/doc/32887060/ma...ation-manua...
It is in the Magnusson supercharger install how to remove it, just one bolt.
