F/S 82mm Throttle body kit.
2010 C63 P31 AMG
I have a complete throttle body set. PM if interested and we can make a deal.
VRP plate
2 MB 550 Throttle bodies (Used, cleaned and working)
2 Original New Renntech Velocity stacks slightly trimmed at the base to mount properly.
Gaskets
Wiring harness
VRP plate
Gaskets
Wiring harness
Please let me know if you would sell the pair of Velocity Stacks separately
2010 C63 P31 AMG
I’ll keep you posted.
2010 C63 P31 AMG
I had some inquiries on the cuts to fit the MB 550 throttle bodies. Even with these cuts the mounting holes do not match up so I am 100% I believe Renntech uses a different throttle body or different MB throttle housing (same inlet diameter, 82mm) compared to what many used on this board for their own 82mm projects. I only cut one side on each to clear the motor assembly for figment purposes then dropped the project. Worse case I would epoxy or glue the stacks down in a way that it can be remove easily if you change throttle bodies in the future in the future.stack inlet and TB match up nicely for smooth flow. hope this answers some questions.
