Bad transmission mounts?
Entire car shakes when selecting PRND. Doesn’t matter if it’s P to R or D to R or N to D etc.
shifts from 1-7 smoothly but that’s while driving down the road.
Are bad transmission mounts the culprit?
I just ordered some new ones from ece that are poly so have more stiffness and should last longer. They also make matching transmission mounts if you want to do them at the same time
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
If changing motor mounts, change your transmission one at the same time.
2013 W204 C63 AMG P31 Estate wagon
Engine mount spanner
If changing the engine mounts you will need this 16mm tool.
https://www.mercedesmedic.com/merced...-mount-wrench/
Does the motor move
If the motor mounts are shot, the engine will noticeably move / jump when the engine is reved.
You also may see leaking fluid from the motor mounts.
