View Poll Results: Oil flow direction
Arch cooler --> Center cooler
![](https://mbworld.org/forums/images/polls/bar2-l.gif)
![](https://mbworld.org/forums/images/polls/bar2.gif)
![](https://mbworld.org/forums/images/polls/bar2-r.gif)
![](https://mbworld.org/forums/clear.gif)
2
40.00%
Center cooler --> Arch cooler
![](https://mbworld.org/forums/images/polls/bar3-l.gif)
![](https://mbworld.org/forums/images/polls/bar3.gif)
![](https://mbworld.org/forums/images/polls/bar3-r.gif)
3
60.00%
Voters: 5. You may not vote on this poll
Oil flow direction
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Does anyone know which way the oil flows through the coolers?
Is the arch cooler "Radiator - Oil Cooler" (assuming there's a bypass inside until the oil reaches a specific temp) fed first then on to the center cooler or vice versa?
Received 2,836 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Up and down and all around
The line from the center cooler goes into the bottom of the arch cooler. I would have thought the inlet would be the higher port. If the inlet is the higher port the arch cooler gets fed first.
