C63 AMG (W204) 2008 - 2015
C63 vs E550
Old Jul 6, 2020 | 12:31 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
C63 vs E550
Ha! This thread is purely discussion.
2014 C63 vs 2014 E550 Coupe (based on C platform)
Tuned C63:
The [TUNED] rating for the ECU upgrade is 540HP and 494LB-FT of torque.
Tuned E550:
The [TUNED] rating for the ecu is 530HP and 606LB-FT of torque.
Obviously you don't get the legendary soundtrack, but I just want to see 2 of these really go at it. Anyone run one before?
Also, you can just throw M157 turbos + tune on there and make 700+ hp ez.
Old Jul 6, 2020 | 12:51 PM
blurred's Avatar
2013 C63 P31
I'd rather see what they actually put down at the wheels. However assuming the transmission is the same, and same gear ratios (i'm not going to look it up) the c63 will slowly walk away as it has higher revs and peak power at higher revs. It will always have more axle torque once moving and will be in lower gears longer. It is also lighter. If you are talking about dig races then its up to tires and driver so no longer about the power of the cars and driveline potential
