C63 AMG (W204) 2008 - 2015
wtb: used M156 camshafts
Old Jul 22, 2020 | 05:31 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
as long as they are not clogged with metal shavings, and are straight and true. looking for any used set of m156 camshafts, even ones with scored up lobes. free would be good if they are damaged, but will pay for them as well. thanks!
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jul 23, 2020 | 06:01 PM
DavesMeanE's's Avatar
Former Vendor of MBWorld
93' 500E, 95' Corolla
I have a couple sets! Why don't you come get your TCU tuned this weekend at Autohaus Burlingame I'm sure we can work something out, I can bring them with me... DM me
Thanks!
Dave
Old Jul 24, 2020 | 04:21 PM
skullbox15's Avatar
2014 C63
I'm curious what you're going to use these for?
Old Jul 25, 2020 | 09:19 AM
go team's Avatar
2012 C63, GL63, 1989 300CE
He’s probably going to treat it and make comparisons?
Old Jul 25, 2020 | 10:28 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Curious also, I looks around at one point with respect to grinding stock Cam's, Jones Cams will regrind to anything you want and have done M156 cams, but they just regrind them so seems you will just get more of the pitting exposed and they don't build them up so you get a tiny bit less lift after they grind. VRP uses stock cams for their grind but they said they have them built up a bit and reground, assuming just at the tip where the cores are worn and they need more meat on the tip.
I have also seen, I think on Taso's channel welded cams eat up lifters as the weld is much harder and chews up lifters even faster, so not sure welded reground cams will be better or worse.
Old Jul 25, 2020 | 01:31 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
He's probably making a bar stool lol.
Old Jul 25, 2020 | 03:27 PM
Top Answer: 1
Haha or a coffee table, bet you are right!
Old Jul 25, 2020 | 11:55 PM
go team's Avatar
The metal’s too soft it would fail.
