C63 AMG (W204) 2008 - 2015
Slipping transmission on the facelift. Anyone found a solution?
Old Jul 25, 2020 | 08:35 AM
Martziniuk's Avatar
C63
So my transmission has been slipping in basically all gears between 1000-1500rpm. This makes the car jerky and difficult to drive slowly. It’s fine on WOT just between those RPMs
A Merc specialist looked it over today and did a software update on the transmission but this doesn’t appear to have fixed the problem.
I’ve seen many posts about this but have never seen any solution. I’d like to try get some kind of solution before the warranty runs out.
Car is a 2013 so MCT
Old Jul 25, 2020 | 10:31 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
If you still have warranty just keep pushing, it has a problem that isn't normal. Software is the quick and easy fix, after that they will probably look at replacing the valvebody/mechatronics and the clutch pack or just swap the whole trans out with a reman. Regardless it isn't normal so keep pushing them before the warranty is up.
Old Jul 26, 2020 | 03:28 PM
Edition1c63's Avatar
C63 amg coupe
Mine has started doing it since I got it tuned. It has a very abrupt down shift. Could be that if your car is tuned
Old Jul 26, 2020 | 03:52 PM
Martziniuk's Avatar
C63
cars tuned I believe but I have no shifting issues apart from the slip.
the latest transmission update makes it creep a little more when in drive which is good and the downshifts come in earlier but the slips still there.
