Be sure to inspect you pulley's and their bearings often!
https://www.skf.com/sg/products/roll...ctid-6203-2RSL
I did find a higher speed option but required custom ordering and specification of grease type to support the higher rpm range. from F.A.G. Bearings. don't think I'll put in the effort for only 4 bearings. also their side seals will leak which means shorter service life if you aren't repacking the grease. if repacking they'll last a lifetime.
2. thanks for the update I upgraded mine in 2023 when you first posted. have about 62000 miles on them, (NO "racing" miles that I will admit to)
3. Hope to see new products in 2026, be safe
