RESET the N/A 1/4 record once again!
Eightysix tuned
headers fueling and weight reduction
10.69 folllwed by a 10.65
49 degrees and -300 da according to dragy
https://youtu.be/_gzlzDXLpdQ
https://youtu.be/vBkYCYYhvsc?feature=shared
https://youtu.be/UiFQMyocBMc
I think mine (fully gutted though) is slightly under 3300lbs now. One of the events I go to every year has the circuit and strip rented. I should yank the wing off and give her a rip down the strip.
i doubt your car gutted is even 3400lb
should be in the 35xxlb range!
- Recaro pole position drivers seat
- Passenger seat
- Rear seat and bench
- Carbon trunk
- Space saver front wheels
- Clk rear wheels
- Smaller rear brakes?
Anything else?
Things to get it lighter
- Titanium exhaust.
- Carbon doors, trunk lid and hood.
- Poly rear glass and front windshield.
- Thin out wire harnesses.
- Carbon driveshaft (only saves 8-10lbs though)
- Helium in the tires?
- Titanium exhaust.
- Titanium exhaust.
I know the door panels don’t weigh much at all, id be willing to delete everything inside the rear ones and the subwoofer too if it got me close to that weight but still think I would be 150-160 off
If gzim335 got 3610 and the only extra it looks like I would do is the sunroof delete over his probably 20kg but I wouldn’t do a carbon truck/his wheel set up, Before I start the major stuff I have got at least 22kg out of it from wheels, brakes & exhaust but I need to weigh some more things to see how much more it might be. I know the kw struts a definitely lighter than stock and so are the adjustable arms I have put on.
I forgot to mention that 3400 was with the AC completely removed.
