C63 AMG (W204) 2008 - 2015
Blue smoke on start up!
Old Aug 10, 2020 | 03:32 PM
VIMike's Avatar
2012 C63
Hey guys looking for some advice. Ive got a 2012 c63 that just turned over 80,000km (50,000miles). Lately ive noticed a small puff of blue smoke on startup. It only seems to happen on a second start up after a short drive. Never the first start of the day. Was wondering if this is a common problem with these engines and if anyone else has experienced this. Ive owned the car four years now with no problems yet. Thanks for any help
Old Aug 10, 2020 | 03:36 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
if a compression test passes, i'd look at the PCV valve. it may be passing a bit too much crankcase vapor into the intake manifold.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 11, 2020 | 06:27 AM
C63AMGeez's Avatar
W204 C63
It is common and happens for me every now and then. I recommend get a catch can and clean out your intake manifold while you’re there.
Old Aug 11, 2020 | 10:38 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
This is nothing to worry yourself about, just oil from the crankcase ventilation that is recycled into the intake and wasn't burned off until you restarted your engine.
Old Aug 11, 2020 | 05:08 PM
ecohen2's Avatar
I have had that occur since my car was new. It usually happens on a hot day after a short drive in traffic, then turning the car off for maybe 30 minutes and then restarting. If you drive hard or on the highway for a while it never happens...
@Yuille36 is exactly right...
Old Aug 11, 2020 | 06:18 PM
Yuille36's Avatar
This is the same principle, when you see cars burning oil, that blue smoke follows them. The difference is their car is burning a lot of oil, and yours is just burning maybe a cap full that happened to be inside the intake manifold.
Old Aug 12, 2020 | 06:54 PM
VIMike's Avatar
2012 C63
Yes this is pretty much exactly what happens. And it has only happened since the summer began. That’s a relief to hear. Thanks
Old Aug 14, 2020 | 01:34 AM
bradsm87's Avatar
W204 C63 Wagon
Mine does the exact same thing and only after the previous run being a very short run (eg. moving the car). Nothing to worry about IMO. I just take it for a quick drive around the block if I have to move the car then it doesn't do it on the next start.
Old Aug 14, 2020 | 09:54 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Both mine have done it, usually after when I wash it, as I start and move it a couple times then next start some smoke.
