C63 AMG (W204) 2008 - 2015
Left rear indicator not working warning
Old Aug 25, 2020 | 01:31 AM
chctim's Avatar
W204 C63 2009
Recently had some paint and panel work done on my left rear door after a minor scrape. As part of the paint blending, work was done on the front passenger and rear panel.
As part of this the tail light assembly was removed. After collecting the car I noticed the left rear indicator warning showing as well as the light blinking on the dash faster. Sure enough the LEDs are not flashing. I checked all the wiring and connections, everything appears to be as it should be. The panel beater had their auto electrician check it over and they've concluded, despite the fault coming up while they had the car and the light unit out, they did nothing wrong and the unit is faulty.
Can anyone recommend what to check if there is anything I have missed. Is this an easy fix or will the whole tail light unit need replacing? Car is an 09 wagon.
Last edited by chctim; Aug 25, 2020 at 01:35 AM. Reason: Forgot to add year/body of car
Old Aug 25, 2020 | 11:38 PM
Ludedude's Avatar
2014 C63 Coupe
If you had insurance cover the repairs then the claim can likely be amended to cover the undiscovered damage. At least that’s how it would work here in the states.
it’s highly suspect that the same corner that was hit and worked on somehow coincidentally turned out to be faulty.
