New Owner - Some Transmission Woes
Downshifting from 4th to 3rd (in manual mode) between 1k - 3k revs results in an aggressive jerk every time. It doesn't happen when manual downshifting in C, S or S+ but sometimes on an enthusiastic drive it will happen in S / S+ automatically without me downshifting. If I apply the throttle slightly as I downshift it can sometimes counteract it and not be as aggressive.
Another issue I have is pulling off from lights I feel like the transmission is a little slow to pick up and isn't as sharp as I would hope, almost allowing the engine to rev slightly before it catches up. This is heightened on first start when the car is cold.
I did some searches and see that many people have had similar downshift issues which have been cured with a transmission fluid replacement, I have had this carried out and unfortunately it has not got rid of it,
Any thoughts or advice would be welcomed! Many thanks..
https://www.weistec.com/media-events...9transmission/
To offer a point of reference, my MCT shifted smoothly before a transmission service and was exhibiting some odd shifting behavior immediately afterwards (including that slight "rev up and go" bit from a standstill mentioned in the OP).
After reprogramming shift points, the smoothness returned.
Good point, however, on the transmission software potentially being modified (or even in need of a factory-issued update). Something worth looking into.
