C63 AMG (W204) 2008 - 2015
On my way to the moon! (200k)
Old Aug 26, 2020 | 12:51 PM
Venom63's Avatar
2009 Mercedes Benz C63 AMG
Old Aug 26, 2020 | 01:02 PM
Ninjadom's Avatar
C63 2011, 125 Edition
Nice!!! How does it run? How much maintenance does it require now?
Old Aug 26, 2020 | 01:06 PM
Venom63's Avatar
Drives amazing like the day I bought it. As far as maintenance just oil changes pretty much.
Old Aug 26, 2020 | 02:08 PM
Mort's Avatar
Milestone!
Old Aug 26, 2020 | 04:55 PM
doncmleon's Avatar
2012 C63
Congrats man!!
Old Aug 26, 2020 | 06:35 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
12 years 200k miles and your engine mounts are still ok?
Old Aug 26, 2020 | 09:16 PM
Dogtag114's Avatar
2009 c63
What major repairs have been done? Headbolts? Cam adjusters? Lifters?
I'm at 102k and eliminated my commute, so I think I'm going to try and stretch mine out a few more years.
Old Aug 26, 2020 | 11:39 PM
roadtalontsi's Avatar
10 C six trizzle
please tell these clowns it has stock headbolts already so i can stop seeing that thread and new ones about headbolts every week.
Old Aug 27, 2020 | 08:38 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I think you found the secret sauce, the rest of us barely drive these things and all kinds of stuff seems to break, seems the secret is to just drive it!
Old Aug 27, 2020 | 12:03 PM
Venom63's Avatar
The engine mounts were replaced @ around 155k
Old Aug 27, 2020 | 12:04 PM
Venom63's Avatar
Have never had to do any of the listed repairs or replacements. The biggest repair was the infamous intake manifold corrosion that caused cracks.
Old Aug 27, 2020 | 12:05 PM
Venom63's Avatar
Correct, I am still using the factory equipped first design headbolts.
Old Aug 27, 2020 | 12:07 PM
Venom63's Avatar
Couldn’t have said it better.
Old Aug 27, 2020 | 01:09 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
How are the upward facing ball joints on the front LCA?
Old Aug 27, 2020 | 01:18 PM
Venom63's Avatar
As a matter of fact one side is squeaking a little but no clunks yet and visually it looks fine but I will definitively replace the whole arm eventually.
Old Aug 27, 2020 | 01:21 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
If the ball joint is still ok, try and get some grease in there. The arms are expensive.
Old Aug 27, 2020 | 01:22 PM
Venom63's Avatar
Defintely was thinking about that the other day. Thanks for the suggestion !
Old Aug 27, 2020 | 08:11 PM
sunnys14's Avatar
2009 C63
Any tips on how to do this?
Old Aug 27, 2020 | 08:29 PM
Venom63's Avatar
Poke a small hole (size of a straw from a wd40 can) then spray some white lithium grease in there. After your done take some adhesive sealant and cover up the hole.
Old Aug 28, 2020 | 05:03 AM
Ninjadom's Avatar
What were the symptoms of the intake manifold cracking? How much did it cost to repair?
Old Aug 28, 2020 | 09:25 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
You will need a proper heavy-duty lithium complex grease made for ball joints. White lithium you use to lubricate door hinges and hood latches won't cut it.
Old Aug 28, 2020 | 10:37 AM
Venom63's Avatar
Rough engine idle. Limp mode. Not much because I bought the upgraded aluminum throttle body plate kit that RMT sells for a couple hundred.
Old Aug 28, 2020 | 10:39 AM
chassis's Avatar
2017 GLE350 4MATIC
@Venom63 Congratulations, a great accomplishment!
Old Aug 29, 2020 | 02:26 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Any tune or mods?
