C63 AMG (W204) 2008 - 2015
Ambient Air Temperature Sensor (Used for engine management?)
Old Sep 23, 2020 | 12:20 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Question Ambient Air Temperature Sensor (Used for engine management?)
Can anyone confirm if the Ambient Air Temperature Sensor is used for engine management? Not IAT, the one that shows outside temp on your dash.
I have mine unplugged and tossed the sensor in the trash since I don't need it on a track only car. and it does actually throw a CEL when unplugged --> P2070 The outside temperature sensor has a short circuit to ground.
I was picking up some parts at the dealership and shot over to service to see if they'd do custom coding (big nope) and the SA seems to think the sensor is actually used. At least for the turbo cars it apparently is he wasn't certain about the M156 platform. Maybe it's used for SAI or AC operation which I also have removed.
Old Sep 23, 2020 | 12:44 PM
chassis's Avatar
2017 GLE350 4MATIC
@Jasonoff Is it possible to “code” the sensor out by installing a resistor in the harness connector? Assuming you haven’t cut the connector off the harness. Do you still have the sensor to measure resistance?
Old Sep 23, 2020 | 12:48 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I still have to get stuff coded out and this was on the list but I am more concerned with it actually being used or not.
Old Sep 23, 2020 | 01:27 PM
blurred's Avatar
2013 C63 P31
Doubtful it is actually used as ambient temperature is not required for any sort of engine management. It would be part of the hvac system for certain.
As you'll find, it is better to leave all sensors attached and working if you're continuing to use the stock ecu, track car or not. Once you have gone to a standalone you can get rid of any redundant wiring harness to save weight and complexity. for now, there is no reason to toss random sensors tbh.
Old Sep 23, 2020 | 03:35 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
My brake cooling duct took over the sensor location. Wouldn't have thought an outside temp display sensor would throw a code.
I also removed my washer fluid reservoir. No code with the level sensor removed. You saying I should put it back in?
Old Sep 23, 2020 | 08:27 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Confirmed it's not used for engine management.
Old Sep 24, 2020 | 02:46 AM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
engine computer does read the ambient though even if not used for anything.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Sep 24, 2020 | 07:47 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Do the turbo cars use the same ECU? Could by why that sensor is associated with the engine computer and why it would throw a CEL when unplugged even though it's not used on our platform.
Old Sep 24, 2020 | 09:46 AM
blurred's Avatar
2013 C63 P31
Ok... don' remove any sensor that makes the ecu happy.
Old Sep 25, 2020 | 06:48 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I read a lengthy document in WIS sometime ago. I remember the M156 has 3 temperature sensors:
1- The MAF sensor has a temp sensor, but it is ignored by the ECU.
2- The intake manifold has the IAT sensor which I believe is the one used for engine management.
3- The front ambient temp sensor is used by the SAM unit for HVAC operation.
I find it strange that sensor #3 throws a code when unplugged. Perhaps it can be used by the ECU in case sensor #2 fails.
Old Sep 25, 2020 | 02:24 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
I heard it was actually used to read more the road temp than air temp.
Old Sep 25, 2020 | 11:03 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Our cars use it for HVAC as well. But nothing engine management related.
Old Sep 11, 2023 | 03:56 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Sorry gents I can't find a pic, what's the standard location for this? I have it hanging near the horn/secondary air pump
Old Sep 11, 2023 | 04:40 PM
DarkMirror's Avatar
2009 C63
I literally just learned about this while my bumper was off this past weekend and forgot to plug is back in. It lightly snaps in at a certain angle behind the grill.
Old Sep 11, 2023 | 04:43 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Mine is also behind left lower grill on black series, I don't remember where it was on my facelift c63 but guessing it is somewhere there.
I looked it up and it was pretty unhelpful, (100 on the diagram) right diagram is for M156)
Old Sep 11, 2023 | 06:28 PM
Adi-Benz's Avatar
Oh wow, no wonder I can't figure it out with the bumper off the car lol 😂 thanks guys
Old Sep 12, 2023 | 12:59 AM
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
If you disconnect it you'll find you get a engine check light... or atleast a fault code in the ENGINE ecu.
That alone is enough to tell me it probably is related to how the engine runs IE what its expecting to see air temp wise going into the engine/across the mafs.
These things are kinda touchy I just had to clean my mafs with maf cleaner to get rid of a couple of other maf related codes aswell as fix the wiring on the temp sensor above which is why I know.
Old Sep 12, 2023 | 07:34 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It's used for the HVAC system which is why it will throw a code. It's not used for engine management on this platform.
Old Sep 12, 2023 | 10:22 AM
DRBC43AMG's Avatar
Yeah, understandable that it's used for the HEVAC system, but can't see it having any relation to engine management. That would come from the MAF I would imagine.
Old Sep 12, 2023 | 04:38 PM
eightysixtuned's Avatar
W211 E63 AMG
this sensor is ONLY used as ambient temp sensor for the ECU (ancillary use) and Dash Cluster.
the temperature sensor for the engine computer and the engine operation is built into the MAF sensor like it is for all vehicles that utilize a MAF sensor.
Old Jan 3, 2025 | 02:13 PM
Gypsi's Avatar
You need the sensor on the automatic or you get horrible shifting when cold. Cold start program like choke on old cars won't run long enough if your temperature senser if faulty
