C63 AMG (W204) 2008 - 2015
Steering issue (any help appreciated)
Old Oct 12, 2020 | 01:41 AM
Urbxn's Avatar
2009 C63
Hello all! This is absolutely driving me crazy. About a week ago, the steering on my 09 C63 got super tight (still drivable), and sometimes it'll make a super loud screeching noise. I checked the power steering fluid and its full, I looked underneath and there's no power steering leaks or any swelling on the steering rack. I'm not sure what to do. Could somebody help me out?? I included the video, and you can see how tight the steering is and you could hear the noise to (ignore me and my buddy)
Thank you all!!!
File Type: mov
Old Oct 17, 2020 | 10:25 PM
Urbxn's Avatar
2009 C63
You sure? The noise is definitely coming from under the vehicle. I also have no check engine light, or any lights at all actually.
Old Oct 18, 2020 | 07:30 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Hard to tell anything from the video but mostly there are 2 things that seem to happen to C63 steering.
First - filter clogs in power steering reservoir, it is built into and the fix is replace the reservoir which is cheap, $50 or so and then change the fluid while you are at it. It will cause lack of fluid getting to rack and make some noise.
Second - pump gives up - usually after a lot of lock to lock donuts - expensive as you have to replace the pump.
I don't think I have ever heard of someone doing a new rack, maybe one time but the rack is the most reliable part of the steering system.
Old Oct 18, 2020 | 10:04 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Change the reservoir and flush the fluid. Done.
