C63 AMG (W204) 2008 - 2015
Oil leaking onto exhaust manifold?
Old 11-23-2020 | 11:05 AM
Arnav's Avatar
2013 Mercedes-Benz C63 AMG (C204)
I was off on a drive last night and when I got home I noticed some smoke coming out of my engine bay. I think there's a bit of a drip falling onto my exhaust headers. Anybody have an idea on where it's coming from? I attached some pictures.
Old 11-23-2020 | 11:09 AM
DRBC43AMG's Avatar
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Valve cover I suppose, but I didn't know the M156 suffered the same sickness as the older M113 engines
Old 11-23-2020 | 12:37 PM
Arnav's Avatar
I would guess so, but I have a facelifted car so the valve cover hasn't been opened since it left the factory.
Old 11-23-2020 | 01:03 PM
dcpatters's Avatar
Veteran: Marine Corp
W204 C63 AMG
Does it smell like Oil burning? If so, most likely valve cover gasket. As you mentioned, since yours is a newer M156, it's not the head bolts.
Arnav (11-23-2020)
Old 11-23-2020 | 01:12 PM
Arnav's Avatar
Weird question, I think you're right but what does oil burning smell like?
Update: smells like diesel
Old 11-23-2020 | 02:58 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Just had my driver's side valve cover gasket replaced on my 2013....
Old 11-23-2020 | 03:02 PM
Arnav's Avatar
If I may ask, how much did it cost? Looks like that's the route I'm going down.
Old 11-23-2020 | 03:27 PM
roadkillrob's Avatar
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
My 2014 leaked there same area back corner drivers side, put a new seal on it and was good for a while then started leaking about a year later and pulled it again and found a crack and had to replace it. Valve cover was about $300 bucks and I did it myself, takes about 2 hours to replace if you take your time, probably could do it in an hour and a half or less now, just having the right tools to get to a few of the back bolts helps a lot.
Old 11-23-2020 | 06:04 PM
wawy's Avatar
Here it would be around 600 CND if you went through MB..
Old 11-23-2020 | 06:19 PM
JonsAMG's Avatar
2010 C63
I would bet money it is a leaking valve cover. My passenger side did the same. I replaced both sides in about 3-4 hours. It’s not too hard, there’s a DIY video on YouTube.
Quick Reply: Oil leaking onto exhaust manifold?
