C63 AMG (W204) 2008 - 2015
Zinc oil additive
Old Dec 29, 2020 | 01:43 PM
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
Zinc oil additive
I have used zinc oil additive in my older cars that had flat-tapped cams. It is supposed to help prevent wearing of the cam and lifters. I was wondering if this might help the cams and lifters in the m156 engines.
Old Dec 29, 2020 | 01:48 PM
Gazwould's Avatar
S204 C250 CDI Sport
In Dino oil basestocks yes .
4 & 5 , no .
Old Dec 29, 2020 | 03:23 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
LiquiMoly MOS2 and Ceratec are probably the best additives for the M156.
Old Dec 29, 2020 | 06:59 PM
Gazwould's Avatar
S204 C250 CDI Sport
Never heard of WS2 ?
Old Jan 1, 2021 | 08:49 PM
Phil1305's Avatar
C63
I dont ride the liquid moly train! Never have, now that being said doesn't mean its not a great oil/additive.
I run schaeffer's Supreme 9000 in my car and it has higher zddp content along with calcium i believe. Do I think it'll help, I absolutely do. But do some VOA on some oils will give you an idea to make your own educated guess etc. Or looking on BITOG forum. I believe there's plenty of great oils on the market but alot of over hype for them as well. I used to be a royal purple fan boy back in the day. Now I run schaeffer's, motul for most of my performance based engines and Rotella T6 and pennzoil platinum ultra in everything else.
Old Jan 2, 2021 | 01:53 AM
Gazwould's Avatar
S204 C250 CDI Sport
Zinc is about having enough for the drain interval as it sacrificially gets used up , more doesn't mean higher protection in fact too much can really upset the balance of the oil and give some adverse effects .
Old Jan 2, 2021 | 05:43 PM
go team's Avatar
2012 C63, GL63, 1989 300CE
Do VOA’s and UOA’s and also feel out how the car behaves for you. I don’t tag on mine all the time and according to my UOA car has been doing pretty well as far as wear metals go.
This is also why some decide to use different oils for the road vs the track. Iirc it’s been shown that just having fresh oil equated to higher hp gains.
