Mercedes E63 AMG M156 Engine nois
Mercedes E63 AMG 2007
Hey everyone. I am going nuts over her in the land of ice and snow.
i just got myself a E63 AMG 2007.
It's the famus M156 Engine whit the ticking nois...
What is the fix??
What is the fix??
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
If it's TICKING ticking, the most common issues with the earlier M156 engines are with the valve lifters or other parts of the valve train (cams and/or phasers). I am assuming you're not referring to the normal (quieter) fuel injector ticking noise with the hood open.
And, on a 2007 you will also need to replace the head bolts if they haven't already been done.
Second problem: when i drive whit a cold engine i loose power when i accelerate it come and goes in the same time.
I am afraid that you're going to have to have someone at a service shop take a look at it. Based on the intermittent power loss, you likely have a secondary problem as well so you'll need to take it to a Mercedes service shop what knows what they are doing.
