Losing brake fluid from some where!
Hi any ideas where the best next place to look where my car could be losing brake fluid from? I've checked the wheels, master cylinder etc, nothing on drive over night, losing about a cup a week at the moment!
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
If you’ve already checked all hard and soft lines, the next place I’d check is the ABS unit. It’s on the right side of the engine bay, can’t miss it.
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
No loss of pedal pressure? That is a significant amount and if you have no issues with braking and don't see it spraying out under pressure I would suspect reservoir or ABS unit but should be easy to find that much fluid, it will remove the paint off anything it is coating have you removed all the undertrays and looked for a wet spot?
It is leaving a closed system so it is going somewhere and if it isn't leaving spots on the ground then it is leaving spots on one of the under trays somewhere.
Check the vacuum line going to your brake booster, if the master cylinder rear seal is leaking itll leak into the booster and the vacuum from the engine will suck it in an burn it through the engine. That's alot of fluid to go missing without a trace and that's literally the first place I would look. I've seen this happen on various cars.
DRBC43AMG (02-27-2021)
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
Check the vacuum line going to your brake booster, if the master cylinder rear seal is leaking it'll leak into the booster and the vacuum from the engine will suck it in an burn it through the engine. That's a lot of fluid to go missing without a trace and that's literally the first place I would look. I've seen this happen on various cars.
In all cases that's sounds like a lot of fluid disappearing and needs a very close check before something serious happens
Phil1305 (02-27-2021)
