C63 AMG (W204) 2008 - 2015
Need some
Old 02-28-2021, 07:32 PM
BBBC63AMG's Avatar
2014 C63 AMG
Need some
What is The best motor oil for my 2014 m156
Old 02-28-2021, 08:12 PM
BLKROKT's Avatar
Received 2,842 Likes on 1,677 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
None. They run best without oil.
The following 7 users liked this post by BLKROKT:
C63AMGeez (02-28-2021), Cammer88 (02-28-2021), CarHopper (02-28-2021), DRBC43AMG (03-03-2021), hachiroku (03-01-2021), Kriston (03-01-2021), Saurabh914 (02-28-2021) and 2 others liked this post. (Show less...)
Old 03-01-2021, 03:07 AM
DRBC43AMG's Avatar
Location: Land of mountains, cheese, chocolate and watches
12' W204 C63 AMG coupe "T-Rex", 12' W451 Smart Fortwo Pulse (99' W202 C43 AMG sold)
I thought you put in water...
Old 03-01-2021, 05:59 AM
INS1GNIA's Avatar
'13 C63 AMG P31
Oil.....I've just been using pee. Let me tell you, I am saving a TON on my plumbing bill.
Old 03-01-2021, 01:33 PM
See63Run's Avatar
2013 C63 (W204)
Don't listen to them. You want Mobil 1 synthetic 75W-90 with the friction modifier.
Old 03-01-2021, 01:52 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
He definitely shouldn't listen to you. 75w90 for an M156 not really that good of an advice.
OP, just do a simple search there is plenty of info out there.
Old 03-01-2021, 02:07 PM
BLKROKT's Avatar
If you like popcorn, you can also just put 3 sticks of butter and a cup of popcorn kernels in the oil fill location. Run the car for 5min for a delicious (and healthy) snack.
Old 03-01-2021, 02:52 PM
Kriston's Avatar
C63 AMG
I run unicorn blood. My cars exhaust shoots rainbows.
The following 2 users liked this post by Kriston:
hachiroku (03-01-2021), sytfu_colan (03-01-2021)
Old 03-01-2021, 03:36 PM
Vader27's Avatar
2010 C63
Unicorn blood is so hard to find on the shelves these days. It's like it's toilet paper or something.
Old 03-01-2021, 04:01 PM
Dr.Speedfellow's Avatar
W204 c63
Make sure it's mercedes 229.5 spec (not 229.51 or 229.52 they are for different applications).
0w-40 for climate with colder weather, 5w-40 for warm climates without cold weather.
A lot of people and shops use Mobil 1 synthetic or liquimoly. I use pennzoil platinum euro 5w-40.
Try reading these as a starter:
https://mbworld.org/forums/c63-amg-w204/725623-0w40-vs-5w40-oil.html
https://bobistheoilguy.com/forums/th...3-m156.315711/
TJH416 (03-01-2021)
Old 03-01-2021, 04:28 PM
BLKROKT's Avatar
That BITOG thread is pure brain damage
Old 03-01-2021, 05:38 PM
W204 c63
It's probably more informative for the OP than anything you offered here so.....
Old 03-01-2021, 06:00 PM
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
welcome to the internet where a search is only as far as your fingers will take you.
everyone will have their differing options, but my preference is 5w-40 LiquiMoly MolyGen or 5w-40 Motul XCess 8100 with 2 cans of LiquiMoly MoS2. stay away from that generic Mobil 1 stuff. it'll work but there is obviously better out there.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old 03-02-2021, 06:22 AM
DRBC43AMG's Avatar
I assume the 5W-40 Liquimoly MolyGen New Generation MB229.5 compatible is the updated version of the standard LiquiMoly in traditional blue and white bottles?
Old 03-02-2021, 12:57 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
See yellow highlighted areas.
File Type: pdf
Old 03-02-2021, 01:08 PM
SPONSOR
hachiroku's Avatar
MolyGen does not meet the standards that are required by Mercedes and the M156 engine due to excess amounts of antifriction additives.
LiquiMoly bluebottles are a standard synthetic oil without antifriction additives beyond required certifications. you'll need to add MoS2 or Ceratec to this.
__________________
-BARRY
Old 03-02-2021, 01:59 PM
Valvestud's Avatar
Only oils conforming to 229.5 (not 229.51) are "allowed". Attached is the current list of approved oils.
Old 03-03-2021, 05:49 AM
DRBC43AMG's Avatar
Well that is understandable even if the bottle says it meets MB 229.5, but why then is it recommended to add MoS2 or Ceratec for example?
Old 03-03-2021, 08:33 AM
See63Run's Avatar
2013 C63 (W204)
was also wondering about this comment
Old 03-03-2021, 03:00 PM
SPONSOR
hachiroku's Avatar
i'm not an expert on each standard, but it is my understanding if you go beyond a given range acceptable for anti friction additives, you'll be out of spec. MoS2 for every engine I own and for anyone who I've recommended the additive to has only shared the same exact thoughts on the product as myself. the engine will run smoother and feel as though more power is available. Ceratec not so much as it's a different product for a different purpose which is why Ceratec should be cycled in every 2 oil changes or every 20k miles. for me Ceratec has less of a positive impact that MoS2, but i'm using Ceratec to fill microholes with its ceramic additive to assist protection through oil film height.
i only recommend things that i have tried myself if they work.
__________________
-BARRY
The following 2 users liked this post by hachiroku:
BLKROKT (03-03-2021), Cwagon (03-03-2021)
Old 03-03-2021, 04:15 PM
go team's Avatar
2012 C63, GL63, 1989 300CE
Late to the party but this is the best I’ve got.
Old 03-03-2021, 04:49 PM
The Machinist's Avatar
11’ C63 AMG; D2 Audi A8; 15’ Golf TDi; 97’ F350PSD; B6 Audi S4; D1 Audi V8; A2 VW GTi
Ive got to step up my meme game.
I decided to try the molygen for the last oil change and I’ll not be going back.
My idle quality is improved (I believe because my lifters are staying pumped up) my starts are quieter, my hot starts aren’t as tappety as they used to be. That’s all I needed to hear.
My suspicion about the MB spec has got a lot to do with the oil viscosity as they are trying to use an oil with as little parasitic drag as possible.
I am not so sure about the additives exceeding spec not being ok though. API specs are always written as “meets or exceeds” insert spec here. It is generally accepted to exceed the spec as being an acceptable practice.
While special, the M156 is certainly not unique in terms of its oil requirements. It still has Babbitt coated bearings, it has aluminum cam journals, and many other “features” that all engines have had for decades. I think MB is mostly trying to be difficult.
AMGSPY (03-03-2021)
Old 03-03-2021, 05:11 PM
AMGSPY's Avatar
2014 C63 507 Coupe
I can't say I know anything about anything, but my experience with Molygen is the same as The Machinist. Smooth and spooky quiet.
Old 03-04-2021, 04:46 AM
DRBC43AMG's Avatar
So it would seem the Molygen 5w-40 seems to be making things much quieter. Seeing the first reviews and positive comments, I would go for this one when changing my engine oil. Probably we can also do away with the additional additives.
However after searching the LiquiMoly internet page for Switzerland where I live, they don't stock Molygen. They only have the purple/blue stuff. Need to search around.
Old 03-04-2021, 04:10 PM
SPONSOR
hachiroku's Avatar
yeah who knows, probably to do with long service intervals and their makeup up until that point of being changed, fuel economy, protection, and maybe emissions.
According to some sources on the internet the purple and blue bottle are the same. This is their standard fully synthetic oil. I haven't used this myself, but as with Motul 8100 I'd also add MoS2 to this if I ran it. With MolyGen, the cost is higher, but as you mentioned I'm not needing to buy 2 bottles of additive which do add to the cost. Much easier to have an all in one solution.
__________________
-BARRY
DRBC43AMG (03-05-2021)
Quick Reply: Need some
