C63 AMG (W204) 2008 - 2015
TheCamberKing F1 fabrications
Old Apr 22, 2021 | 06:24 PM
The Machinist's Avatar
11’ C63 AMG; D2 Audi A8; 15’ Golf TDi; 97’ F350PSD; B6 Audi S4; D1 Audi V8; A2 VW GTi
Has anyone ordered parts from them recently?
i have tried contacting them via every way I can think of:
FB
eBay
direct email
im at a loss.
I get one time one word responses and then nothing.
Old Apr 22, 2021 | 07:19 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I think I initially contacted them in IG and then the rest of the correspondence was thru email.
Old Apr 22, 2021 | 08:13 PM
He finally got back to me on FB. Now it looks like it’ll be another week before he’s got any.
Old Apr 28, 2021 | 06:16 PM
downhiller2010's Avatar
C63
anyone compared these to the kits upd offers?
Old May 3, 2021 | 07:43 PM
The UPD kits look fancier, but that’s about it.
Old May 3, 2021 | 08:02 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Actually they are quite a bit different. First thing is that the UPD arms use spherical bearings versus what looks like poly on the F1 arms. This makes a difference in articulation of those joints.
Old May 3, 2021 | 08:51 PM
Hardly justifies the $2-300 price difference.
Id rather have the poly anyway, they last longer, and have better road manners.
Old May 3, 2021 | 11:56 PM
BLKROKT's Avatar
Ok that’s fine, whatever. I was just trying to help correct your prior post by pointing out that they are indeed different. Sure they’re both threaded rod so I guess they’re similar, as any aftermarket arm would be. Many of us have no need for road manners and would rather have a firmer arm with greater range of motion. I’d be replacing the F1 poly with sphericals anyway before they even got here.
I don’t particularly like the double locking nut design of either as they tend to slip and twist under load. I’m about to take mine out to correct that as well as replace the shïtty cheap sphericals UPD ships with theirs. I might also add that the UPD arms contact the frame on full compression (and only on full compression) and damage the arms - my straight arms each have a 1/4” deep divot taken out of them. I’m going to have to grind down a frame edge while they’re out, and the arms may be trashed depending on what I see when I get them out. When I reached out to ask if they would replace just the arms, they were real dïcks about it, so UPD customer support is about as bad as it gets if that helps make your decision easier.
Old May 4, 2021 | 01:30 AM
radvinb's Avatar
2013 c63
Any other options out there?
Old May 6, 2021 | 04:28 PM
icon420's Avatar
this place is a joke
I have the F1 and they seem good to me. They are quiet with lots of adjustability havent had any issues with them at all.
Old Jul 28, 2021 | 05:06 AM
Phil_T's Avatar
C63 AMG Saloon
I am also looking at arms at the moment but would like to hear more reviews on the F1 arms from people that have had them on for a while.
I hear the kmac ones have issues with noise and now as above the UPD contact the frame!
Old Jul 28, 2021 | 08:10 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
For UPD there's a passenger side tab you need to grind down a bit so the toe arm doesn't make contact. They have instructions apparently that outline this in the install steps.
After I used loctite on all the nuts they seem to be pretty decent and they've been through quite a bit of abuse. Around 6-7 track days so far.
Old Jul 28, 2021 | 12:50 PM
sytfu_colan's Avatar
C63 Coupe
The F1 end links are weak, I ended up replacing their rod ends with FK rod ends.
Customer service was great, I blew the end links and they replaced them, but blew them again later.
I also have the rear adjustable control arm and its held up. Had to use a tiny bit of blue loctite to prevent them from breaking loose.
