C63 AMG (W204) 2008 - 2015
Engine Light after installing new air filters
Old Aug 15, 2021 | 11:47 AM
dderisi's Avatar
C63 AMG S
I recently replace stock air filter with K&N Performance Air Filter and I am getting a P2188 “System Too Lean at Idle Bank 1” and a P0171 code means that, on the first bank of the engine, the fuel system is running weak or a vacuum leak exists near this side of the engine. Any suggestions on how to correct this?
Old Aug 15, 2021 | 12:35 PM
roadtalontsi's Avatar
10 C six trizzle
try again
Old Aug 15, 2021 | 01:17 PM
dcpatters's Avatar
Veteran: Marine Corps
W204 C63 AMG
Check the air box lid is properly installed and fitted. Did you remove entirely the air box to install the filters? Perhaps when reinstalled, the Y-pipe to airbox inlet is loose or leaking.
Old Aug 15, 2021 | 08:29 PM
dderisi's Avatar
C63 AMG S
Thanks! Will see if it is properly installed and no loose hoses.
