C63 AMG (W204) 2008 - 2015
M156 Engine Startup Opinions
Old Sep 29, 2021 | 05:18 PM
MercWyo's Avatar
W211 E55 AMG
I haven't had much experience with the m156s and got this startup video from a seller. Does anyone have any issues with the sound?
Engine has 75k miles and was maintained at merc dealer.
Concerned about camshaft adjusters and the odd 'ping'. Can't tell if it is just the video/audio location or if something else stands out. Also there is a bit of tapping for a short time.
Thanks so much for the help. Trying to make a quick decision on this vehicle.
Old Sep 29, 2021 | 06:46 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
needs adjusters initial rattle and likely the short tapping sound. A lot of these have the start up rattle but that constant tap sound needs replacement
Old Sep 29, 2021 | 09:51 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Sounds pretty typical for Cam Adjusters at that mileage, a bit of rattle at startup but it does sound like it stops, if it doesn't then they may be too worn and need replaced. Starts as early as 15 or 20k and gets longer as the miles increase, about what I would expect to hear at those miles - good news is there is a repair kit now, so a lot cheaper to fix as the kit is more like 600 bucks total vs cam adjusters at 600-700 each. Budget a couple grand to have it fixed with the kit in the next 20 or 25k miles I would suspect if you are paying to have them done.
The rattle is what it is and the Cam Adjusters will work for a long time rattling, what you really want to do is scan for codes and make sure there are no codes for timing indicating the cam adjusters are not just noisy but unable to lock and then they throw codes and need repaired.
Old Sep 29, 2021 | 10:08 PM
INS1GNIA's Avatar
'13 C63 AMG P31
It always amazes me that people don't clean or wipe down the engine bay area on cars they are selling.
Old Sep 29, 2021 | 10:25 PM
MercWyo's Avatar
W211 E55 AMG
Thanks for the insight everyone. I was concerned about the tapping, but it also seems to go away after a few seconds...
thoughts on the tapping?
Old Sep 30, 2021 | 12:14 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
It’s pretty simple:
a) Do you like the tapping/rattling? Then don’t worry about it, it’ll get more frequent and louder.
or
b) Do you not like the tapping/rattling? Hope you have $3-5k handy.
Old Sep 30, 2021 | 12:54 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
engine sounds fine. that is the cam adjuster and is what i would consider normal. the engine sounds healthy to my ears.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
