C63 W204 Dashboard Removal
I am new to this forum, but not to C63 Ownership. i own a Fire Opal Red C63 Coupe
My vehicle was broken into someone attempted to steal it.
the botton of the Dash was rippedd apart near the EIS unit
I have purchased a New dash and started removing most stuff from it
is there any guide anywhere on how to remove the Dashboard. i am guessing i will need to remove the steering wheel as well
thanks,
thanks,
I managed to break the passaeger air bag connectors :/ i dont know what i can do to fix them
re: airbag - if you haven’t had the Takata recall done yet, just take it to a dealer and they should sort it out for you (hopefully free)
remove the dash vents by using a plastic pry tool
remove surrounding plastics
remove the parking sensor and the vent that is around it. there is a tricky screw there
basically remove all screws you can see
remove the A pillar cover theres a screw under the air bag clip
remove the screens and intrument cluster
remove the centre console
there is many hidden screws what i done was removed what I can and pulled the dash to see what is holding it
i would not want to do it again
i found replacement clips withh need to strip and crimp them together and hopefully will not get an air bag light
Good job getting the dash off and replaced.
i don't think i would want to pull another dahboard apart after doing this.
