UPD Intake Spacers, installed.
C55 Wagon Midnight Blue, SL55 Brilliant Silver, E55 Designo Mystic White
I purchased these, then saw all the negative posts here about them not fitting so got concerned.
Only way to get them on, is to unclip the hard plastic y-pipe off its seat on manifold, rear of engine, then place the spacers, and begin screwing everything back in a trial and error sequence.
It is a tight fit, but no leaks or codes.
I am happy, and as you can see, used two of the metal things for more height on front engine cover.
Price difference between my p30 and a p31 means the couple hundred dollars for more hp makes sense.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
They raise the included performance filters up into red spacer, creating unobstructed path for air to it.
OEM design has them 'hanging down' in the tunnel disrupting the flow, but also likely creating condition where only part of filter sees the action and therefore gets blocked up with debris first.
Members here are hostile toward them, for some reason, preferring the 'placebo' effect that obstructions do not matter.
I have no idea about actual gains, but long as no leaks or codes, they will very unlikely be slowing me down.
From memory and because I bought other stuff, UPD discounted its price to match similar product at VRP...
http://ultimatepd.com/2003-2007-merc...boost-kit.html
2 - Because the person that bought and installed them based on the manufacturer claims of 25whp gains doesn't want to spend more of their money to be proved wrong
3 - Because people that are on the fence don't want to waste their money on these plus a dyno in order to prove the claims
I would dyno test them if someone sent me a set but no way would I purchase them on my own because I don't believe you would see decent gains.
Why don't someone make a dynotest with a temporarily setup?
Duct tape and some material to space the boxes up would be the same, and good enough for a result.
Dirt cheap and those who want to prove the manufacturers wrong, can get their results so they can go full kill on this forum
If my dyno could take cars i would have done it already =)
Already did this. Picked up 3 hp going from stock filters to kn and charcoal delete
then to see how much rows could potentially add we did as you said and had no filters and open flipped lids. 2 hp more than kn setup
Diabolis (12-10-2021)
Any potential gain of course comes as a result of reduced air flow restriction, NOT because of any spacers where all other things are the same. The air in the airboxes is turbulent (the MAFs themselves on the clean side provide much more of an obstruction than that corner of the paper element in the airbox), and how smoothly the air flows doesn't really come into play until you are well into the intake runners. It always comes out the same way through the air filters.
Thanks for sharing and doing the testing in the first place.
P.S. Another thread on the same topic: https://mbworld.org/forums/c63-amg-w...er-review.html
ALFAitalia (12-11-2021)
Ya that’s what I got out of it. The air filters already flow enough there is almost no restriction. I’m in the camp that can’t see how a spacer would add power in this situation as no filters entirely offers almost no noticeable difference.
car designs since mid 1930's have been about harnessing airflow, same thing that keeps aircraft aloft.
without the spacers, intake has inexplicable obstruction, akin to the boxy cars capone used to drive in 1920's.
couple hundred bux is not much and should only concern p31 guy who refuses to match.
There is no obstruction that they fix, a spacer might help if the air was being pushed into the engine, but since the engine is pulling vacuum then the engine is sucking air through the filter so there is no obstruction, ram air pressure will only overcome the vacuum at about 300 mph, so they might help if you can get them to add enough power to get you to 300mph.
If you want to read more about resonant airboxes, here's a good article (it is written mostly with motorcycles in mind but applies equally to both bikes and cars alike): https://motorcycleinfo.calsci.com/Airboxes.html
