Considering a Manual Steering Conversion (Track only car)
Naturally, these cars are not going to be identical but he could build a base model GT around the M156 since the m159 is just the better version, but the idea remains that a toned down version is feasible, especially if he is interested in serious/heavy track use.
I'm not questioning his use of the car at all, I was saying why not start with what the Baby Jesus intended? If its the bill, I get it.
I'm not putting a GT car on the road anytime soon either so...I just was curious why he was using this as a base for his track car is all.
MAYBE he could tell me something I don't necessarily know and I could learn something new possibly.
vs
https://racecarsdirect.com/Advert/De...class-w204-dtm
I'll leave now, I'm a hijacker on accident.
L O OOL
Need to find an M16x1.5 plug to use in place of the banjo for the outlet. Will use the inlet and existing hose as a fill port to keep the gutted housing body/bearings cool while it's spinning without load.
Should be able to do a test with an emptied rack after the weekend.
I don't have much room, maybe FL is different?
With the PS cooler gone I could use the green box real-estate so my block-off pate can stay put and it's above the bumper beam even though I have since removed some of it.
FL might be different idk, my 2015 507 certainly had different interference issues than others with the other cooler upgrade.
Not going to remove any parts but you can see it in there
Gutted pump worked perfect as an idler. The steering was WAY too heavy though. Ordered a new pump (yeah I could have re-assembled but considering it's 12 years old better to put a new one considering the abuse it will take)
With the front tires off the ground I could move the wheel back and forth with one hand by the spoke. There was virtually zero resistance in the rack with it empty.
The problem wasn't that it was just heavy. You couldn't turn the wheel very fast when moving which is critical on the track, it would have been dangerous.
